I have a Ricoh MP 2554 that won't connect to a couple of fresh updates to Windows 10 when I try to scan to folder.
I have several Windows 10 Pc's that are working OK, they scan to folder without any problems.
I'm getting the following message when I "browse the network" to try and connect to these W10 Pc's:
"Connection with the destination has failed. Check the settings."
I have double, triple checked the settings; I've compared them with other Windows 10 machines that are connecting just fine.
We're running Windows 10 ver 1709 16299.125. I have others running the same version working ok.
I thought it was because these two specific Pc's had problems because I wiped the HDD back to factory (Windows 7 pro 64 bit) then upgraded to Windows 10 pro 64 bit fresh after all W7 updates.
But I just tried a third Pc which was wiped to factory W7 / upgraded to W10 and I can browse the network to this Pc just fine and I scanned a document to it just fine.
Does anyone have any ideas or hints as to what I need to do or try to get these to work for scan to folder?
