Password reset on a Ricoh MP 3554
  • beyonddriven0
    • Mar 2018
    • 5
    [Misc] Password reset on a Ricoh MP 3554
    I misplaced my password for the Ricoh MP 3554. I tried every variation of admin and supervisor combination (including blank) I don't want to factory reset the machine, as we have the mail SMTP setup as well as all the users.
    Does anyone have a service code for this machine or know of another way to reset the password w/o resetting everything? Any help is greatly appreciated.
  • AMS
    • Jun 2017
    • 73
    Re: Password reset on a Ricoh MP 3554
    This works on 4502 so it may work.. Go into the factory service mode. Not the standard service mode. Reset,1,4,3.clear, hold clear again for 5 seconds. Then your in factory mode. sp 5846-46. Execute that and when you turn the machine off and back on just enter your new password or just hit OK to enter no password. hope this is what your looking for. The sp may be different in the 04 then the 03's but the name should be the same.
    • beyonddriven0
      • Mar 2018
      • 5
      Thank you @AMS - I tried using the code above and it didn't work. The printer doesn't have physical buttons, so I get to a screen where I can enter the code and nothing happens. Could it by chance be a different code for the 3554?
      • TonerMunkeh
        Professional Moron
        • 3869
        Not possible from WIM, has to be done in front of the machine.
        Hit it.
        • beyonddriven0
          • Mar 2018
          • 5
          Thanks TonerMunkeh - What I meant was, will it reset the web login? Or the physical interface login?
          • FrohnB
            • Jul 2017
            • 1919
            I believe you can go into user tools -> system settings -> administrator tools -> down one page to "Program/Change" Administrator and then you can change the passwords in there. You may have to log in at the user tools screen as "supervisor", (if you don't have an option to log in, then change the "admin authentication" in user tools). Hope this helps.
            Omertà
            • beyonddriven0
              • Mar 2018
              • 5
              Hi @FrohnB - Tried to go in there and change it, but it's asking for a PW.
                • 36689
                Originally posted by beyonddriven0
                Thank you @AMS - I probably should have clarified this in the first post. Is this for the web login reset? Or is this for the physical login at the machine reset?
                Ideally I'd like to reset the web login if that's possible.
                Thanks again for your help with this.
                They are always the same.
                • guitar9199
                  • Sep 2016
                  • 1098
                  If you go into the "Document Server" app on the screen, you will get a keypad that you can use to go into SP mode with.
                  • beyonddriven0
                    • Mar 2018
                    • 5
                    So I was able to get in with Reset 8,0,6,1,8,2 clear - But when I am in, 5846-46 wasn't there. Is there any wording I am specifically looking for so I can reset the correct one?
                    I appreciate all of your help.
                    -Eric
                    • guitar9199
                      • Sep 2016
                      • 1098
                      I appreciate all you guys and your help.
                      -Eric
                      That's because it's not in Regular or Special SP mode...it's in FACTORY SP mode. Scroll up for the procedure on how to get into that.
                      • FrohnB
                        • Jul 2017
                        • 1919
                        "AMS" is right (and guitar9199), Factory mode, 5846-46, cycle machine, and it should be defaulted back to "admin" with no password.
                        Omertà
                        • sandmanmac
                          • 3967
                          It won't default to "admin", it will only reset the supervsior credentials, so then you can log in and reset the admin credentials.
                          Oh yeah...it will also wipe out the entire address book.
                          BTW.....Factory SP mode has no business being shared in a public forum.
                          Yes, I know it's been done in the past, and I've been critical about it then too.
                          If you wish to share info like this, that's what PM's are for.
                          • Oze
                            Ricoh Fanboy
                            • Jul 2008
                            • 1663
                            +1
                            • fuwei2422
                              • Nov 2014
                              • 49
                              read the NVRAM send the file to my mail:fuwei2422@163.com
                              i can help you ,
