auto reset to job end on ricohs
  • Urushiol
    • Sep 2009
    • 22
  • LNorris
    • Sep 2008
    • 646
    Re: auto reset to job end on ricohs
    i tell my customers to always press the yellow reset button every time they walk up to the machine.
      • 36689
      Sounds to me like a training problem for the salesman. Minimum auto reset time for system and functions is 10 seconds.
      • sandmanmac
        • 3967
        Originally posted by Urushiol
        You can even enable auto reset at job end on ricohs for the scanner function, using Scanner SP: SP1-012-001 “User Info Release” change setting to a 1. Surely there must be a way to do this in copy mode.
        It's not the same at all.
        User info release is just that, it releases the user but none of the settings that user may have set until the programmed scanner reset time is reached.
        As suggested, it seems to me that telling them to press reset then copy is a pretty small ask. It's never been an issue for me.
        • DRichard
          • May 2008
          • 482
          Originally posted by sandmanmac
          ...it seems to me that telling them to press reset then copy is a pretty small ask.
          WHAT ARE YOU TALKING ABOUT??? A customer's time is very important! How could we possibly expect an end user to push an additional keystroke that would solve their entire problem without having to create an additional problem no matter how imagined it may be??? HOW DARE YOU, SIR?!!!
          "Enjoy every sandwich."
          -- Warren Zevon
          • Urushiol
            • Sep 2009
            • 22
            Alright, I appreciate the replies.
            The customer can adapt, but isn't it our job to make things easier for them? You all act like I'm crazy for even posting this.
            You got to understand in a large company with lots of users, who are accustomed to a way their previous copier operated(which they had for 10 years!) that there will be some transition time. That old habit will die hard. It will take some time, but it will die.
            I don't think it unreasonable for them to press one extra button. I just figured if we could help them eliminate errors or problems by removing one thing for them to remember it would be good.
            It's fine that there isn't a solution to this, I just don't understand your attitudes.
            • DRichard
              • May 2008
              • 482
              You as the purveyor of the NEW equipment must make clear the design differences that go along with it AT THE OUTSET. By trying to accommodate their old expectations, you do them a disservice and create unnecessary headaches for yourself. Explain to them why not having the machine instantly reset itself is a PLUS and not a design limitation. You need to have an experienced sales rep spend some REAL time training the new users on why your equipment is a better alternative to the old fleet of machines. If done properly, you will find yourself dealing with actual service issues and not imagined or user-created problems.
              -- Warren Zevon
                • 36689
                You sir are a total idiot. We have never had any problems instructing customers to clear settings. We have never had complaints from customers about having to do so. BTW, I have been working on copiers since 1972. How long have you?
                • DRichard
                  • May 2008
                  • 482
                  TOTAL idiot? (have you been talking to my ex-wives?) Your professional assessments of my very limited abilities is duly noted. I bow to your advanced years. Please accept my congratulations on surviving the last ice age.
                  -- Warren Zevon
                    • 36689
                    At my age, I don't have time to put up with idiot like you. Don't bother responding because you have been added to my ignore list.
                    • DRichard
                      • May 2008
                      • 482
                      Nooooooo!
                      -- Warren Zevon
