Ricoh ARMS
  • anothertech
    • 1755
    Ricoh ARMS
    We are using Ricoh ARMS every day here, but we have not gotten the firmware update to work yet. Has anyone used ARMS to update firmware? If so, any tips/tricks?
  • Dark Helmet
    • May 2009
    • 829
    Re: Ricoh ARMS
    Ive done it on a few machines. It usually takes 2-3 attempts to get all the firmware to update as it seems to only install half the required firmware.
      • 36689
      Re: Ricoh ARMS
      Check the firmware history document for your model. Most older models will require that the System/Copy firmware be at a or above a certain level before updating through @Remote will work.
      • zed255
        How'd ya manage that?
        • 1025
        Re: Ricoh ARMS
        I have not had much luck pushing via ARMS, but I have had firmware work via @Remote using the Centre Server.
        For me ARMS has been nearly useless.
        • anothertech
          • 1755
          Re: Ricoh ARMS
          When I press update in ARMS on my smartphone, it looks like it is working, but I do not see any indication at the Ricoh machine. What should I look for at the machine so as I know it is working.
          • anothertech
            • 1755
            Re: Ricoh ARMS
            The machines I am using to test are current machines with pretty much up to date firmware, just a version or two behind. @remote updates work. There are no instructions in the ARMS manual to tell how to do the updates or what indications on the machine to look for.
            • skinnyb
              • Jul 2008
              • 291
              Re: Ricoh ARMS
              Same here.
              Sent from my VS987 using Tapatalk
