RICOH PRO 8100 SC 460-01
  • monkees
    • Jan 2011
    • 40
    [Error Code] RICOH PRO 8100 SC 460-01
    Hi guys
    I have this code sc 460-01
    already replaced flat belt transfert - opposite roller - kit 600 k - kit 1200
    run SP 2 234 002
    have you had similar cases ?
    thanks for the replies
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: RICOH PRO 8100 SC 460-01
    T & S power pack failure!!!!!!!!
    Also there are 2 opposed rollers to change in that ITB unit.
    Mystic Crystal Revelations
    • anothertech
      • 1756
      Yes, the one that opposes the drum, and the one that opposes the PTR.
      • monkees
        • Jan 2011
        • 40
        Maybe you haven't read it right
        I wrote that I changed already opposite roller and the kit where there is the other roller
        • RG1964
          • Jul 2009
          • 56
          Could it be a bad contact at the seperation (ptr)?
          The contact screw loose.
          Had a simular problem at a Pro C 7100.
          • monkees
            • Jan 2011
            • 40
            Also in Italy we read the manuals
            Completely dismantled the PTR
            I found under the cleaning roller a clip
            • imaginemoko
              unTrusted Tech
              • Jan 2008
              • 289
              Try RD179052b if it could help you Sir. else try testing ITB power pack.
              fix the customer first then fix the machine... its simple and makes life more easy.
              • JOLYNAR
                • Nov 2012
                • 44
                If you want i know the specialist in your country for that kind of Copy machine. Write me in private message for he phone Number
                Inviato dal mio RAINBOW JAM 4G utilizzando Tapatalk
                • monkees
                  • Jan 2011
                  • 40
                  I solved thanks
                  • dpoutz
                    • May 2011
                    • 78
                    I solved thanks
                    Hello what was the resolution? thx
                    • cesarzz
                      • anothertech
                        • 1756
                        Kannst du bitte auf Englisch posten?
                        • monkees
                          • Jan 2011
                          • 40
                          I replaced the full ptr
