MPC 3003 Slow Printing
  • keithxxiii
    Just a tech
    • Nov 2014
    • 469
    Gents,
    I was scratching my head on this issue. Firmwares are updated, HDD reformatted, Printer App, NCS has been reset but still prints slow in some particular PDFs.
    The PDF was the scanned document from the device. If you compare the print speed from a word-converted PDF, it prints fast within 2 seconds. Tried printing thru my cable and got the same slow result.
    The printer driver is a UPD since the device is connected to a Print Management software.
    *it prints slow on scanned documents only!
    I have simulated the same document to an older device with the same print driver and guess what, it prints within 4 seconds! I called up the IT to try to install the normal PCL driver from ricoh to test it. Awaiting for his input as I am on my way to visit the site.
    Aye! Cut the crap
  • thetechnician
    • Aug 2018
    • 4
    Re: MPC 3003 Slow Printing
    Have you tried telling it to print the pdf as image?
    • TonerMunkeh
      Professional Moron
      • 3869
      Unless it's running a solution, switch Java off with SP 5730. That has a dramatic effect on print speed due to more available memory.
      Hit it.
      • Mark Bbb
        • Jun 2012
        • 1662
        You write:
        "The printer driver is a UPD since the device is connected to a Print Management software."
        There is your problem (my guess)
        • keithxxiii
          Just a tech
          • Nov 2014
          • 469
          Originally posted by Mark Bbb
          You write:
          The solution design was a central printer queue then the job will be released to any of the devices (MPC 3003, MPC 4503 and MPC 3002). I will give it a try to setup a central queue with the original PCL driver and see the results. BTW, it prints slow on the MPC 3003 only
          Aye! Cut the crap
            • 36689
            Also check that the port is set to TCP/IP. Microsoft has a nasty habit of installing printers on WSD ports.
              • 22801
              yup THANKS MIRCOSOFTIE! that's one reason I got out of computers years ago... constantly changing OS... costing me $$$ each time.
              • copier tech
                • 8095
                Interesting, I may start turning this off on a few of my devices & monitor the print speed.
                • 8T2
                  • Aug 2015
                  • 257
                  I disable WSD print and scan on all the devices I install, just saves time on callbacks due to slow printing or with user codes not working because WSD installed Ricoh class rubbish driver
                  • keithxxiii
                    Just a tech
                    • Nov 2014
                    • 469
                    UPDATE:
                    Printed thru FTP = within 3 secs
                    Printed thru direct cable = 5 seconds
                    Printing thru network = 25 seconds....
                    I have asked the IT to change the ports maybe? from his switch
                    We'll see tomorrow for the update
                    Aye! Cut the crap
                    • mikadonovan
                      • May 2008
                      • 2936
                      This may be a shot in the dark, but there are fuser temp and idle settings that effect print speed. Run a non-default smc and see if any of these have been taken out of specs. After re-reading your last post, this is probably not the case. 25 seconds for network printing = network issue I would say.
                      NEVER ASSUME ANYTHING
                      • fshead
                        • 2356
                        i see that WSD all too many times...........
                        • fshead
                          • 2356
                          not to hijack a tread but is JAVA the issue with the c3003 taking so long to load all options on full restart ?
                            • 36689
                            My experience is that if JAVA is enabled, you cannot get into most SP and User Tools options until it finishes loading (abut 5 minutes).
                            • keithxxiii
                              Just a tech
                              • Nov 2014
                              • 469
                              Update:
                              I have asked the IT to trace where the port is connected and try to change it. Was waiting for his tracing tool and there it goes. When he changed the port, it worked like charm.
                              Thanks for all your suggestions. Highly appreciated!
                              Aye! Cut the crap
