@remote issue on MPC3004
  • MatthewS
    • Nov 2012
    • 36
    Hello Guys,
    I have a machine that was on @remote and all suddenly stopped working. There is 2 MPC3004's in the building on the same network and the other MPC3004 @remote is still working. On the problem machine I have performed SP's 5816-201, 5870-003 and 001. Trying to re-register machine on @remote is no go and thinks about it for 10 min then times out. Machines firmware is up-to-date. Any suggestions?
  • TonerMunkeh
    Professional Moron
    • 3869
    Re: @remote issue on MPC3004
    Is it a Basil box or Cumin communication? Are you using WIM or SP modes to put the @remote code in?
    Hit it.
    • MatthewS
      • Nov 2012
      • 36
      I am using Embedded RC Gate method and registering via WIM.
      • keithxxiii
        Just a tech
        • Nov 2014
        • 469
        When you say "trying to re-register", did you remove it from the central server and performed 5816-209 and 5870-003 and 001?
        Aye! Cut the crap
        • zed255
          How'd ya manage that?
          • 1025
          You need to have it removed from Centre Server, do SP5-816-209, SP5-870-3, and either SP5-870-1 (for a 512 bit certificate) or SP5-879-4 (for a 2048 bit certificate). With the newer devices the 2048 bit certificate is preferred and required for features like AFU.
          Don't discount the possibility it is an IT thing. Had one a while back where one device would not register and it turned out the customer was filtering traffic on that one subnet.
          • MatthewS
            • Nov 2012
            • 36
            Yeah I did remove it from the central server and performed 5816-209 and 5870-003 and 001 then checked 5816-201 in exact order. Once I do all that then I go to WIM and try to register with new request number. It's hard to believe in this case it's network causing issue considering the other machine on same network (same IP range/subnet) is currently connected to @remote.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              When we've had @Remote issues in the past we used to run SP5-870-3 and SP5-870-1 to re-write KeyInfo and that usually resolved the issue.
              And what failure error code does it give you?
              Have you tried setting @Remote up only using the SP settings?
              EnterService Mode.
              SP5-816-062– Use Proxy – Change 0 to 1 if Proxy Required
              SP5-816-063– Proxy Host – Type Proxy Server Name
              SP5-816-064– Proxy Port – Type Proxy Port Number
              SP5-816-065– Proxy User Name (if Needed)
              SP5-816-066– Proxy Password (if Needed)
              SP5-816-200– Manual Polling to check/update status
              SP5-816-201– Check result is 0 before starting
              SP5-816-202– Letter Number - Type RRAP Request number
              SP5-816-203– Confirm Execute
              May take a minute & a couple of 200 (Manual Polling)
              SP5-816-204– Confirm Result – Check reports 0 before continuing.
              If 9 the 200 again until reports 0
              SP5-816-206– Register Execute
              SP5-816-207– Confirm Result – Check reports 0 before continuing
              SP5-816-209– Instl Clear – Deletes all settings above to re-try.
              ForTesting once registered open User Tools, System Settings, Administrator Tools
              Onthe second or third page there will be a Service Test Call button and a NotifySystem Status
              • MatthewS
                • Nov 2012
                • 36
                It comes up with this message. (FYI there's no proxy server on network)
                I have tried setting up @remote using both WIM and SP mode methods.
                • keithxxiii
                  Just a tech
                  • Nov 2014
                  • 469
                  Agree with Zed, you have to check if they are filtering the traffic on that particular IP. Also check if you can ping the central server's IP.
                  I always have my netgear extender and connect to 3G to test the connectivity of the device.
                  Aye! Cut the crap
                    • 36724
                    Just wild hair but have you tried it connected to the same network that the one that is working is connected to? I have managed switches blocked selected port on selected circuits.
                    Had a major account once that after painting the shop office over the weekend and moving everything back in, MFP would not print. After working on it for about 90 minutes their local IT and I noticed that there were 2 jacks in the office. Moved the cable to the other jack and it started spooling. IT did some further checks and when configuration used to be done remotely by corporate IT they had set the switches to allow TCP/IP printing only to selected switch ports.
                    • anothertech
                      • 1756
                      Tell me more about using this Netgear device to test.
                      • keithxxiii
                        Just a tech
                        • Nov 2014
                        • 469
                        I use my phone's mobile tethering to set up my own small network. Then connect the printer to the extender to connect to @remote website.
                        Aye! Cut the crap
                        • Kimi
                          • Feb 2018
                          • 105
                          Have you checked the network settings on the device? This fault could easily be the gateway address is wrong.
