Ricoh MPC5501
  • scanmc
    • Mar 2015
    • 178
    [Jamming] Ricoh MPC5501
    I don't do a lot of work on Ricoh's but I've got this one out in the field. My issue is when duplexing the machine gets about an inch out of the fuser when entering the bridge then jams (J024 code) I pulled the exit assembly from a very low meter parts machine and installed it with same results. Machine will run all day on simplex. Any help would be appreciated.
  • LNorris
    • Sep 2008
    • 646
    Re: Ricoh MPC5501
    has it printed on both sides, then misfeed as it exits or is it flipping the page over when it misfeeds?
    • FrohnB
      • Jul 2017
      • 1919
      Re: Ricoh MPC5501
      J024 is a Junction Gate Sensor. I would suspect maybe the junction gate is "cracked" from heat from the fuser, and allows those teeth on the shaft to move or fall off. Or maybe the "arm" on one of those guides (that the solenoid engages with) may be broke or missing.
      Omertà
      • keithxxiii
        Just a tech
        • Nov 2014
        • 469
        Re: Ricoh MPC5501
        Agree... It happened to me already
        Aye! Cut the crap
        • scanmc
          • Mar 2015
          • 178
          Re: Ricoh MPC5501
          Thanks for the info. Heading back out here today for a closer look.
          • JDYAL
            • Sep 2008
            • 186
            Re: Ricoh MPC5501
            x3 I've had this happen also.
            • TonerMunkeh
              Professional Moron
              • 3869
              Re: Ricoh MPC5501
              Replace D029 4580.
              Hit it.
              • Athlontini
                • Jun 2012
                • 269
                Re: Ricoh MPC5501
                Originally posted by TonerMunkeh
                Replace D029 4580.
                This. Ricoh refers to it as an "open/close guide" and they released a TSB for this.
                • scanmc
                  • Mar 2015
                  • 178
                  Re: Ricoh MPC5501
                  Well It ended up being the gate shaft and bushings were so gummed up that the solenoid would open or close properly. After a good cleaning she's working like a champ again. You would thing after all the years of doing this I would remember the KISS rule.
                  Thanks to all who responded!
