Ricoh MP-301 locked out of menu features
  • Robinh
    • 114
    I sold my first MP-301 to a local dentist, and their IT guy set it up to scan to folder. Worked fine for the first 90 day, then the customer tried to set it up to scan to Email and the scan feature quit working. The customer brought their IT guy back, and he threw his arms in the air, and passed it back to me. I am now unable to access some features in the user tools menu, like setting the IP address. We tried doing a memory clear SP5-801-11 and all that did was reset the IP address. I apologize if this should be an easy answer, but I'm stumped, can you help me?
    Thanks,
    Robin
  • FrohnB
    • Jul 2017
    • 1919
    Re: Ricoh MP-301 locked out of menu features
    I have run into this with the 301 before. In my case it was a firmware upgrade that took care of it.
    EDIT: Had something to do with the SMB 2/3 updates. Just like your case, we were unable to get into interface settings and such.
    Omertà
    • NeoMatrix
      Senior Tech.
      • 3514
      Most likely cause is using a fixed MFD IP address in/along side all the other computer DHCP assigned IP address on the network.
      If the customer turns their computers on first before the MFD, then the DHCP server will assign their computers/roaming laptop to the fixed MFD IP address.
      Reserve the MFD fixed IP address at the DHCP server, or use DHCP on the MFD itself, an use hostnaming convention for the MFD IP addressing.
      Alternatively, turn off all DHCP, an assign fixed IP addresses for "ALL" devices on/entering the network.
      HTH
      • copier tech
        • 8096
        Did the IT guy set an Admin password?
        Also as stated update the firmware.
        • tjvincent
          • 280
          I've had this where you can't get into the network settings on the panel to change the IP, it had the wrong LCD firmware installed, make sure you have D1271498C installed
          • Robinh
            • 114
            He swears it's their policy not to change a default password, and he knew it was supposed to be Admin and blank, but we're also unable to access the logon button.
            • Robinh
              • 114
              HTH
              Most of this went over my head, but I'm going to try and figure this out.
              • CopyBats
                • Aug 2011
                • 133
                Have you confirmed if the IP address has an access control range setup? Go to the copier and go to user tools. Then go to Printer features, and you will see an option for config page. Upload that here so I can have a quick look.
                If it works, don't touch it.
                • Robinh
                  • 114
                  I don't have a config page, but I'm going back tomorrow and will print one. I do have a win test print page, attached.
                  Thanks again for your help.
                  Robin
                  • sandmanmac
                    • 3967
                    Robin
                    Yeah....I'm afraid this is of no help to anyone
                    • copier tech
                      • 8096
                      Robin
                      With all due respect I would escalate this to one of your work colleagues who atleast has a tiny bit of IT experience.................
                      • keithxxiii
                        Just a tech
                        • Nov 2014
                        • 469
                        we had this one recently... yep it was the operation panel firmware after all. So update all of your firmwares
                        Aye! Cut the crap
                        • Robinh
                          • 114
                          I've been a tech for 38 years, at one point in time I was a regional service manager for Danka, my first home network was Lantastic. ;-)
                          Today, I'm self employed, it's just me. I only sell the segment one Ricoh, and I tell my customer's that I will support their IT guy. I installed this machine and with the help of their IT guy, we set it up to scan to file, it was working great, the customer and their IT guy messed with it and can't get it fixed. So my options are limited.
                          If I can't figure it out, I might call in a favor from one of the guys who used to work for me, but I'd like to take a shot at figuring it out myself. :-D
                          Thanks for the help
                          Robin
                          The customer called me up the other day, said the Ricoh wasn't printing their checks from Quickbooks correctly. I ran over, and helped them figure out how to align their checks in Quickbooks Online. This job doesn't get any easier. :-/
                          • NeoMatrix
                            Senior Tech.
                            • 3514
                            ...snip..
                            Yes Robin (Male); appreciate your humility. 38 years is plenty of expertise.
                            Re. Job expertise.
                            When you add in I.T. the job doesn't get any easier. The more you learn the more people expect for you to pull miracles out of you're backside. It's all part of being a Tech'o or IT guy. Add in the fact that I.T. has a million different software flavours and machine platforms; you can reach to point of grey hair early in life, if you haven't tore it all out before then.
                            Years ago as a running prank I made up hand full of business cards with the slogan "Professional Know I.T. All". Some people saw the funny side of it....
                            I'm tempted to make up another similar business card with "Professional Santa Claus --Free Gifts For All."
                            Keep plugging away at the IT. your on the right forum. The guys will assist where they can....
                            • adoug
                              • 23
                              Did you try using the WIM and log on as supervisor and change the admin password there??
                              Also make sure the DNS settings 1 and back up DNS setting are not the same pretty sure that will allow printing but stop scanning.
                              Try resetting user info think it's so 5 832 6 also.
                              Hope this helps some what.
