Richo MPC4504ex with Papercut - will not display a new scan location add address book
  • dave w
    • Jun 2015
    • 230
    Any help please
    At a customer who have a new Ricoh MPC4504ex With PaperCut installed.
    The MFP will not display any new address entries in the main scan to Folder list (not the papercut menu).
    I can edit a previous listing and that will show but will not show any new address book entries.
    updating fw as I type this, Is there anything im missing?
    Thanks in advace
    Dave w
  • guitar9199
    • Sep 2016
    • 1098
    Re: Richo MPC4504ex with Papercut - will not display a new scan location add address
    Did you check the "Add to Frequent Users" box?
    • dave w
      • Jun 2015
      • 230
      Hi
      Yes and also in the Title 1 .
      update
      can now add a address from the address book managment on the panel and can see in scan to folder, but still not via browser
      Also noticed out of 70 email address only 3 can be seen.
      • guitar9199
        • Sep 2016
        • 1098
        Are you adding them through the Web Image Monitor, or standing at the control panel?
        • sparks45
          • Jun 2014
          • 25
          You have to remove all authentication from the device (administrator, custom, network etc), then add your entries to the address book, then turn back on all the authentication again.
          • keithxxiii
            Just a tech
            • Nov 2014
            • 469
            Maybe "Key Display" is not entered when adding a name from Web Image Monitor.
            Doing it from the operation panel automatically adds the "Key Display"
            Aye! Cut the crap
            • dave w
              • Jun 2015
              • 230
              Many thanks for your help guys.
              Update
              Standing in front of the machine and adding the scan to folder address is all there appart from the folder authentication (user name and password) that seems to be missing.
              But when you do add a test address it is via the smart panel it's seen in both PaperCut and the MFP scan to folder page.
              When adding the address book via WIM all looks correct but when you stand infront of the MFP the folder info is not there.
              As a work arround I edited a old address in the address book they did not use from WIM and that did work.
              Spoke to Ricoh-PaparCut and they are looking into it, It seems that the new Smart Operation Panel machines are a new development for Papercut as they normaly load PaperCut via Java and the process is diffrent with the new Smart Operation Panel devices.
              Thanks Sparks45
              I have taken note and will keep that in mind when I return
              Many thanks aging
              Dave w
              • sparks45
                • Jun 2014
                • 25
                it is a known limitation with the new PaperCut embedded on the SOP's, removing all the authenitcation and adding the entries into the address book will work, i have had to do this at a few customers. you may even need to remove PaperCut also, although i didnt need to last time i did it.
                • keithxxiii
                  Just a tech
                  • Nov 2014
                  • 469
                  Update
                  Thanks Sparks45
                  Many thanks aging
                  Dave w
                  Even on other print management softwares, the embedded installer is different for SOP. That is why we still use the classic applications instead of the new apps that come with SOP
                  Aye! Cut the crap
                  • Kimi
                    • Feb 2018
                    • 105
                    this is the correct answer and what i do when this issue occurs.
                    • dave w
                      • Jun 2015
                      • 230
                      Many thanks to all
                      Copytechnet Respect!
                      • Batman1976
                        • Jun 2016
                        • 88
                        Hi Guys,
                        I have a MPC6004ex with Papercut doing exact same thing with scan to email via the device address book. Has there been any firmware updates or feed back from Ricoh or Papercut?
                        Cheers Batman 1976
                        • dave w
                          • Jun 2015
                          • 230
                          Originally posted by Batman1976
                          Hi Guys,
                          Cheers Batman 1976
                          Hi Batman 1976
                          Our customer got to a point that they had Papercut removed dueto loads of issues.
                          Luckly I was on site when it was removed as lots of sp modes had to be adj to get it back to orig config.
                          Good luck
                          Dave
                          • diedux
                            • Jan 2017
                            • 124
                            Know this is old post but still relevant. Had this same issue on Ricoh IM C2000 with PaperCut few days ago.
                            To enter address book destination its enough to temporarily disable User authentication. Set Device Management > Configuration > User AuthenticationManagement > Custom Authentication to Off.
                            After making changes in address book turn User Authentication back on and check scanner archive settings. Navigate to Device Management > Configuration > Scanner > General Settings.
                            In Print & Delete Scanner Records, make sure "Do not Print: Delete Oldest" is selected.
                            Hope this helps.
                            • twalker
                              • Aug 2017
                              • 7
                              If you go to the address book using the web image monitor, click on a user, go to the Protection section, click on the Change button next to Access Privilege, under Public, tick the box Full Control. The user will then show on the scanning screen.
