install apps (cheetah) from server on smart panel
  • djremixer
    • Feb 2014
    • 18
    [Misc] install apps (cheetah) from server on smart panel
    Hi all
    just little question:
    to install ex. "remote panel operation" app or other you can do it with sd card on the panel and install from SD card
    but you have also the option install from server but you need an product ID.
    someone allready have used this option? does someone know if this works? does every app has his specific product code? where can I find this product code?
    from Wim is there no option to install apps (because you're on the CTL i guess)
    regards
    update: it's not the product ID you can find in the "rempnlope.dalp" file when you extract the firmware
