Ricoh MPC4503 Printing Issues
  • Optimus Prime
    • Aug 2012
    • 6
    [Misc] Ricoh MPC4503 Printing Issues
    Good afternoon,
    I have a problem with a MPC4503 when printing.....
    If you send a 30 page print job for example - it will print out the first 10 pages then it like it forgets what it is printing and then restarts the print job from the beginning then it may print 14 pages then restart.
    If I look at the print job in the print driver while its spooling you can see it show an error and the restart.
    The package firmware is up to date and I'm using the PCL6 driver.
    I've, also got this problem on a MPC2003.Any thoughts will be appreciated.
    • 36902
    Re: Ricoh MPC4503 Printing Issues
    Is the 4503 reporting a jam and then restarting the print after clearing the jam? If so, you have a flaky door switch somewhere, Usual suspect if you have an external finisher is the switches in the bridge unit.
    • mincopier
      • Dec 2015
      • 290
      If going through a surge protector try bypassing that. Had one doing similar.
      • Brianneoe
        • May 2015
        • 318
        try clearing out 5801xxx that relates to the printer. i don't know the sub code, it maybe 007. as always never do a all clear 001 or 002. You can also reformat the HD in 5832 but back up your address book first.
        • keithxxiii
          Just a tech
          • Nov 2014
          • 468
          Is it network printing or tcp/ip printing?
          Is is using WSD port?
          Have you tried reformatting the HDD?
          Have you tried clearing the Printer Application?
          How about NCS? I once had a problem saying "waiting for print data" on the printer screen, after doing the NCS, it started working fine again.
          Good Luck
          Aye! Cut the crap
          • D_L_P
            Self Employed
            • Oct 2009
            • 1196
            Originally posted by Optimus Prime
            ..then restarts the print job from the beginning then it may print 14 pages then restart.
            Sounds likely it could be a duplicate IP address, bad network cable, or failing port on their switch.
            Just to CYA, lock in the LAN speed. Repeatedly losing and reconnecting is a symptom of a failure of the Auto negotiation of the LAN speed.
            • NeoMatrix
              Senior Tech.
              • 3514
              Is the problem print job HTML/XPS pages coming off an internet browser?
              Clear the print spooler directory of all files and try the print job again.
              โ€ขโ€ขโ€ขโ€ขโ€ขโ€ข โ€ขโ€ขโ€ข[ยง]โ€ข |N | โ‚ฌ | o | M | ฮ” | t | ฯ€ | ยก | x | โ€ข[ยง]โ€ขโ€ขโ€ข โ€ขโ€ขโ€ขโ€ขโ€ขโ€ข
              • aktasson
                • Feb 2017
                • 201
                I have had a similar issue, in my case customer has printed out from the internet browser with a pdf document.
                • AjitN
                  • Mar 2009
                  • 287
                  Is the customer is same in both the cases? Is it connected directly through some port OR through Print Server? Which protocol?
                  Which OS & Application software? How is network performance?
                  Try connecting your laptop directly & check.
                  If it is PCL OR PS try changing SPOOL setting as "Start printing after last page is spooled" OR "Hold mismatch document" setting.
                  In case of PS try changing "Send C
                  TRL -D" setting in device setting.
                  Ensure bidirectional communication is ON.
                  I feel if job shows restart in printer driver, mostly it could be OS OR Printer driver setting OR break in network.
                  Hope this helps
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    "I've, also got this problem on a MPC2003." You write.
                    Is this mpc2003 connected to the same network with the same customer?
                    • AjitN
                      • Mar 2009
                      • 287
                      Is it resolved?
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        And it became silent
                        • mremore
                          • Jun 2010
                          • 7
                          I'm with AjitN- I've had this problem in the past. Print after last page spooled has worked for me multiple times.
