EDP code = Model list
  • Voltageza
    • Jun 2017
    • 72
    Hi Guys
    Long shot here. I have a list of part number with EDP codes but no model number. Is there a easy way to lookup the model number, or is there some sort of list that link EDP to Machine model?
  • CopyBats
    • Aug 2011
    • 133
    Re: EDP code = Model list
    Put the part number in precision roller website. It will give you the model numbers that part belongs to.
    If it works, don't touch it.
      • 36689
      EDP codes are for ordering machines, accessories and supplies. If you are with an authorized dealer, check with your order clerk.
      • Voltageza
        • Jun 2017
        • 72
        Hi.
        I can lookup the part numbers but the description does not always say which model uses the part. Also there is a 1000+ parts. Thats why i am looking for some sort of excel/csv file with a partnumber and its model it belongs to so i can do a vlookup.
          • 22801
          Originally posted by Voltageza
          Hi.
          hmm sounds like a great off time project!
            • 36689
            Hi.
            If you have the actual 8 character part number, you most likely have the product code for the model that part was first used. If the first 4 characters consist of a letter followed by 3 digits, that is the product code. Search this site for Goose's Guide. It is on a number of threads. You need the one that has an index sheet.
            • mikadonovan
              • May 2008
              • 2936
              You might try just using Google to search the EDP codes. I just tried a couple of codes, and they popped up in the first 10 suggestions with the nomenclature and models they went on.
              NEVER ASSUME ANYTHING
