MP C305 Toner not set correctly?
  • digicor
    • Jul 2008
    • 1141
    Client put new K toner in, machine says " toner not set correctly" its the right toner, oem, i vaced out the toner hopper sleeve, all clean and making contact with the chip reader, i manually toner up the drum unit, still says the same thing.
    anyone have a suggestion? besides tossing out the baby with the bath water... hahaLOL
  • MitchD
    • Oct 2012
    • 164
    Re: MP C305 Toner not set correctly?
    There is a TSB for this exact issue. Good luck tho, it involves pulling the toner pumps I believe - Which is NO FUN at all.
    Let me look up the TSB real quick......
    "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
    • MitchD
      • Oct 2012
      • 164
      SUBJECT: TONER REPLACEMENT ALERT DOES NOT CLEAR / SC361 OCCURS
      SYMPTOM:The following symptoms may occur: Toner replacement alert does not clear after replacing the Toner Cartridge. SC361.
      CAUSES:This Symptom has two causes, and both causes an SC361 may also be triggered.
      Yep, pretty much have to replace the toner hopper assy for the affected color. I suggest replacing all 4 while you have it that far apart. Im guessing its the black or yellow that wont load.........usually one of those 2
      Good luck, let me know if you need a copy of the TSB
      • sandmanmac
        • 3967
        What level is your engine F/W?
        I found this:
        MP C305 firmware.pdf
        • jonhiker
          • 661
          This is usually the issue, it helps to have a buddy and take pictures when doing this repair and also., might as well replace all 4
          • Zaxxon
            • 608
            Please start you post with brand, model, problem.
            • copier tech
              • 8096
              I found this:
              [ATTACH]41729[/ATTACH]
              I would update ALL firmware before you start spending hours stripping it down replacing parts.
              Take out the toner with the issue shine a torch into the back & check the contact pin is not bent, quite hard to see compare with another colour.
              I’d also try another new toner bottle had a few faulty chips over the years
              • anothertech
                • 1756
                +1 for trying another toner bottle. We have been seeing a fair number of bottles with bad chips in them.
                If firmware was kept up to date on every call, we would do a lot less troubleshooting, but most techs that I know won't take the time to update firmware until there is a persistant problem, then they just update the piece of firmware involved, not everything that's out of date. Frustrating.
                • fshead
                  • 2356
                  that is going
                  "old school"
                  • FrohnB
                    • Jul 2017
                    • 1919
                    Hate these machines. Have replaced many of the toner hoppers (too many) and now I could almost do it in my sleep. We started telling our sales people a few years ago to STOP selling them and pull the one's that were out and replace with different models. Horrible machines.
                    When you remove the affected toner from the machine, is the chute on the bottle open? If so, it could be one of the white "hooks" that engage that chute has a broken spring (shine light into toner cavity, and they're almost all the way to the rear).
                    We have had many bad chips on these bottles (and the newer 306/307 toners too).
                    Most commonly is the toner hopper auger getting mangled.
                    Have also had luck vacuuming out the cavity (really well) and cleaning the post that goes into toner bottle chip.
                    Not a bad idea to update f/w.
                    Omertà
                    • digicor
                      • Jul 2008
                      • 1141
                      Yes as ametter of fact the toner bottle comes out open! what does this mean? is a piece of something stuck in the toner hopper, and yes i vacked out the whole toner shute,hopper, and everything i could reach
                      • copier tech
                        • 8096
                        This is an interesting point, when you fit the toner does it stick out slightly more than the rest? If so then the hopper shutter has become uncliped or broken.
                        • copier tech
                          • 8096
                          that is going
                          "old school"
                          Ok in reality use your "smart phone" !!!!
                          • printertnc
                            • Jun 2015
                            • 68
                            I had a way with this model, and this kind of problem. I have many customers with this type of printer, and I will soon change them. This model MPC305 is cursed !!!!
                            • Athlontini
                              • Jun 2012
                              • 269
                              It usually just means that one of the spring-loaded retainers is out of whack, and is pulling open the chute as you pull the bottle out. I've fixed this by simply taking off the top cover (1 screw!), moving the two laser units out of the way, and reaching in there and fixing it with a spring hook.
                              Once you check that out, I'd recommend trying another toner bottle before you try replacing hoppers. A new bottle has fixed this issue every time for me - I haven't replaced a toner hopper yet.
