Ricoh MP C3300 has a operation panel screen is blank.
  • COPIERMAN
    • Jun 2009
    • 557
    the copier power up notice red light on alert and printer button also has a red light. i can push copy/fax/print/ buttons and the light changes to those items. i have swap op panel assy/controller/ power supply/BICU board same problem op display screen is blank. Has anybody had this problem before.
  • fshead
    • 2356
    Re: Ricoh MP C3300 has a operation panel screen is blank.
    well it s a known issue when the laser unit brd goes it takes out a small resistor on the BICU brd.
    If you pull the laser unit out and look at the board you will see brd components"i forget what they are called as its been a while"
    are bad.
    • ridgemill
      • Sep 2017
      • 180
      From Goose's Guide:
      D023/D025 BLANK DISPLAY display goes black - update scanner fw to 1.24 or higher & system fw to 1.24 or higher
      D023/D025 BLANK DISPLAY No display - check for input voltage, replace PSU as needed
      D023/D025 BLANK DISPLAY no display - cracked soldering on polygon mirror motor pcb
      D023/D025 BLANK DISPLAY no display - update LCDC fe to 1.09 or higher
      Also check if there is an image on the display, by shining a light at it, if you have SC202 replace the polygon and BICU as a pair.
      • COPIERMAN
        • Jun 2009
        • 557
        you are correct shine light has sc 202 code thanks for the help.
        • fshead
          • 2356
          if you pull the laser motor brd you will see some worn solder joints.
          If you search on CT you will find which "tiny" resistor you need to solder on.
          you can find spare ones from old brds or bad brds,a very common component on ricoh brds..
          • Dan G
            • Nov 2014
            • 56
            are bad.
            I would add that both BICU and Laser Polygon Mirror must be done as a pair - if you do BICU only polygon motor will kill another BICU. Do Not chance it
            • COPIERMAN
              • Jun 2009
              • 557
              i found information on the BICU resistor 294 ran a wire over it and everything came back up. Thanks for the help everybody. another job well done by the community of techs.
