Ricoh mp c6004
  • canon.master
    • Mar 2018
    • 22
    Ricoh mp c6004
    Please i need help with this
    after install m toner
  • FrohnB
    • Jul 2017
    • 1919
    Re: Ricoh mp c6004
    Check to make sure your toner chip/ contact points (rear of machine) aren't covered in toner, not getting a good reading.
    Genuine Ricoh Toner?
    Previously used bottle or bottle swapped from another machine? new machine won't accept a previously used bottle.
    Omertà
    • JDYAL
      • Sep 2008
      • 186
      Re: Ricoh mp c6004
      Just had this problem. Bad toner clogged up toner hopper causing the auger inside to break. Had to replace toner hopper and clean out toner supply tubes.
      D1493280 part number
      • FrohnB
        • Jul 2017
        • 1919
        Re: Ricoh mp c6004
        Originally posted by JDYAL
        Just had this problem. Bad toner clogged up toner hopper causing the auger inside to break. Had to replace toner hopper and clean out toner supply tubes. Also check the toner pump. D1493280 part number
        Did not think about this being a cause! Luckily we only had a few of those problems with the xx03 series, but have not had a single xx04/xx04ex exhibit this problem yet. (knock on wood).
        EDIT: Ricoh does have a Service Bulletin for the auger breaking.
        Omertà
        • canon.master
          • Mar 2018
          • 22
          Re: Ricoh mp c6004
          • canon.master
            • Mar 2018
            • 22
            Re: Ricoh mp c6004
            I faced also on bk and after i replace it still work fine
            thank you very much...
            • JDYAL
              • Sep 2008
              • 186
              Re: Ricoh mp c6004
              Have had quite a few bad magenta toners lately. You can actually shake them and hear the chunks in them. Watch out for those, that's what cause my problem.
              • blazebusiness
                SanDiegoCopierRepair.com
                • 1250
                Re: Ricoh mp c6004
                this message appeared [ATTACH=CONFIG]42357[/ATTACH]
                Assuming you have a good new oem toner , it is a toner supply issue. Toner is not reaching the developer unit in the PCDU. To diagnose the cause you will have to inspect the subhopper to see if it is clogged or the auger is damaged. If you don't have the service manual , get one to see the disassembly involved. Not that difficult once you've done it a couple of times. The controller box and harness guide will have to be removed to get to the subhopper.
                Other items that could cause this:
                Toner transport motor
                Toner end sensor
                But those failures would be rare. Usually an issue with the hopper.
                • canon.master
                  • Mar 2018
                  • 22
                  Re: Ricoh mp c6004
                  • canon.master
                    • Mar 2018
                    • 22
                    Re: Ricoh mp c6004
                    Toner end sensor
                    • blazebusiness
                      • 1250
                      Re: Ricoh mp c6004
                      Thank very much ... but with the old toners i didn’t get any problem but know i try more than one same problem
                      At the risk of being repetitive, your toners are probably not the issue.
                      If you are a tech-----download or purchase online the service manual and follow the disassembly procedure to remove the subhopper. If you are not a tech, probably a very good idea to call one.
                      You could also try requesting the MPC 6004 service manual for your machine. Lots of good people here. Some altruistic soul may PM you a link to that manual for free.
                      Hope the advice helps. Followup and let us know what happens.
                      • canon.master
                        • Mar 2018
                        • 22
                        Re: Ricoh mp c6004
                        Thanks again i will try to get the sm
                        • Oze
                          Ricoh Fanboy
                          • Jul 2008
                          • 1663
                          Re: Ricoh mp c6004
                          Count your lucky stars then coz we've had heaps of this issue with '03 AND '04 series breaking augers
