SMTP over TLS (STARTTLS) on MPC300
  • keithxxiii
    Just a tech
    • Nov 2014
    • 469
    Hi Guys,
    Has anyone configured SMTP over TLS (port 587) on an MPC 300 device?
    I was supporting the guy remotely and asking him to describe what he sees on the operation panel.
    When SSL is turned on, port number disappears. I am just assuming that it automatically assigns an SSL port.
    From the WIM, i manually changed the port to 587 and entered the email, username and password.
    When asked to do connection test from file transfer, it succeeds, but when asked to do a scan, it says transmitting only.
    Am I missing something? or this device does not support StartTLS at all?
    TIA.
    Aye! Cut the crap
  • zed255
    How'd ya manage that?
    • 1025
    Re: SMTP over TLS (STARTTLS) on MPC300
    Pretty sure the MP C300 only supports SSL. The main clue is not being able to input the port number via User Tools. Even though you can change it in WIM it still won't work. Also the connection test is basically just a ping and really does not verify the configuration is correct.
      • 36733
      Too old to support STARTTLS
      • skinnyb
        • Jul 2008
        • 291
        I concur. Have tried many times and it doesn't work.
        Sent from my VS987 using Tapatalk
        • keithxxiii
          Just a tech
          • Nov 2014
          • 469
          Just as suspected. Thanks for the input guys. 1 more query though, if I install their certificate on the machine, will there be any chance that this will work on port 587?
          Aye! Cut the crap
          • copier tech
            • 8096
            Might be worth a fw update?
            • keithxxiii
              Just a tech
              • Nov 2014
              • 469
              Firmware has been updated. Had a confirmation from ricoh as well that GW09 devices does not support TLS.
              Aye! Cut the crap
              • copier tech
                • 8096
                Cheers for the info.
                MP C401 supports ssl maybe time for an upgrade.
                  • 36733
                  There is also the possible of using a local relay computer using a software such as Stunnel.
                  • keithxxiii
                    Just a tech
                    • Nov 2014
                    • 469
                    Hi,
                    Though the case is closed, I'm still curious about SSL and TLS.
                    In the old machines, we use to upload the certificate (trusted root cert from equifax) and it simply works after that.
                    In this case, the customer has their own certificate. Now I'm just wondering if I upload their certificate on the machine. You think there will be a chance that the STARTTLS will work? Has anyone tried this method before? Is it worth a shot?
                    Aye! Cut the crap
