Mpc5000 J003 jam
  • mrfuser
    • 1594
    Mpc5000 J003 jam
    Machine copies fine then as soon as we print it jams j003
    printing letter size
    odd eh?
  • Hoosierdaddy
    • Oct 2016
    • 181
    Re: Mpc5000 J003 jam
    Does it print and copy out of the same tray?
    • Coptech
      worker drone
      • 460
      J003 is no paper pickup from tray one. I would replace feed rollers and see what happened after that.
      • FrohnB
        • Jul 2017
        • 1919
        +1 on Coptech statement. Usually the Sep. Roller, but sometimes the end fence is back too far, or paper is curled up under the stack. A couple things to check anyway.
        Omertà
        • mrfuser
          • 1594
          Replaced Trey 1 feed assembly and works fine now
          • mrfuser
            • 1594
            Spoke Too soon client called back this morning with same jam!
            • copier tech
              • 8095
              If the machine "copies" fine from say tray 1 but jams from tray 1 "printing only" then you have a printing paper mismatch issue.
              Check LEF/SEF paper size etc.
              • COPIERMAN
                • Jun 2009
                • 557
                cant remember if that use a clutch to engage feed tire if so replace it. Other is lifting of paper if something cause it to bind a little bit and does put enough pressure can cause not to feed properly. maybe to rule out cassette tray swapping to make sure it not causing problem.
                • MIGUELMARCHENA
                  • Feb 2018
                  • 179
                  Swap the feeding feetwho works well, puts it in the box that bothers, so you know if it is for rubbers, sensors, seals etcor if there are other things like sizes etc.
                  • keithxxiii
                    Just a tech
                    • Nov 2014
                    • 469
                    must be a dirty/defective clutch from behind.
                    Aye! Cut the crap
                    • HitMan
                      • Aug 2015
                      • 170
                      The feed unit has a bushing that can cease up at the rear side. Remove the feed unit and you can see a black dirt build up. You can fully strip it but might get away with cleaning with it intact
                      Sent from my SM-G930F using Tapatalk
