Almost all customers' scans to email going to SPAM since this past weekend!?!
  • mlandry71
    • Sep 2014
    • 24
    [Misc] Almost all customers' scans to email going to SPAM since this past weekend!?!
    This week we've been getting calls from all over the state and even across lines that scans to email are all suddenly going into SPAM.
    We initially thought it was just to gmail addresses, but now it's happening on several other email domain destinations.
    Also checked the smtp servers they're using and there seems to be no correlation - i.e. all different servers from godaddy to comcast to office365.
    Had the last customer find the email in spam and select "Not Spam" but the scans STILL go into spam folder.
    What the hell happened over the weekend?!?
  • ThePomqueteer
    • Sep 2016
    • 73
    Re: Almost all customers' scans to email going to SPAM since this past weekend!?!
    Can confirm here in Canada as well. Bunch of scan to email not working calls. Have been calling them getting them to check the spam folder but unfortunately since the machine is doing its job it makes it very hard to find out whats going on. I usually just tell them to get their IT involved. Anything from GMail to ISP SMTP servers. We even tried applying a global GSuite spam filter to allow email from the sender email and it was still going to spam. Asked my friend who works for the dispatch for a local ISP and they don't know anything about it either.
      • 29290
      Most likely a filter update
        • 36685
        Have you tried white listing the senders, that is adding them to the recipients address book.
        • mincopier
          • Dec 2015
          • 290
          Would be nice if customers would learn how to use the software that they choose to use. In this case once the scan leaves the copier and is received by the customers email software the machine is setup. Not our problem. This is what customers computer support is for.
          I understand and we find ourselves in the same position at times.
          • Mark Bbb
            • Jun 2012
            • 1662
            Probabely a matter of security, since computersystems can be hacked through the scanner...
            So it's in the benefit of the client, in the long run.
            • guitar9199
              • Sep 2016
              • 1098
              Change the "Subject" line in the scan settings. A lot of filters look for keywords like "scanned", "attachment", "FYI", using multiple digits in in the "From" address and so on. Ricoh/Savin default subject line is USUALLY something like, "Message from RNP0X0X0B1A4F" or something of that nature. Change it to "Information from Dave's Plumbing" or whatever the customer's company is and see if that gets around the SPAM filters.
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3945
                Great point.
                It's been years, but I've seen this happen before.
                A blank subject line is probably the surest way to get filtered out.
                • ThePomqueteer
                  • Sep 2016
                  • 73
                  Got an email from a tech thinking this may be related to Urgent11
                  URGENT/11 Information from the Research Team - Armis Labs
                  Its above my pay grade but maybe someone whos more knowledgeable in that area can confirm?
                    • 36685
                    Originally posted by fionalam
                    The emails I was sending were also going to people's spam for a while, so I found a few solutions for that. I think that taking an email deliverability test should help with your problem. You will find out what holds your email deliverability back and make sure each email account works to its total capacity. Also, spammers aren't known for being considerate and attentive to their recipients. So, whenever anyone gets a generic-looking email, they're not excited. Instead, they're alarmed. Another thing spammers are notorious for is sending massive amounts of emails. So, it would be best if you worked with email service providers that have the capacity for large email volumes.
                    You are 2 years too late to the party grave robber.
