SPC352 E59 firmware update error
  • sparks45
    • Jun 2014
    • 25
    Does anyone know what E59 error refers to when updating firmware on this model? it isnt listed in the manual nor any other model. Package file in package folder in SD slot 2. Happening on several devices with different SD cards tried
  • HitMan
    • Aug 2015
    • 170
    Re: SPC352 E59 firmware update error
    Not sure but if you do the older method with the rom data folder it will work. It must have something to do with a security fearure
    Sent from my SM-G930F using Tapatalk
    • anothertech
      • 1755
      Many times the Package method doesn't work until the Engine and System are up the a certain version.
      • keithxxiii
        Just a tech
        • Nov 2014
        • 469
        1. You must have an older firmware
        2. The firmwares are corrupted
        3. Try a lower size SD in updating the firmwares
        Aye! Cut the crap
        • paulg
          • Jun 2007
          • 278
          E59 is HDD is not mounted error. So best to check Is the HDD there and is it working as it should? Ricoh UK help desk helped a teammate with the same error. Turned out no optional Hard disk so the package had no where to be saved to.
          • jonhiker
            • 661
            The ricoh usa tsrc site has been stating there is a problem with some of the package firmware. Try again and use the individual firmware files in a romdata folder, as was suggested earlier
            • DRichard
              • May 2008
              • 482
              Make Sure your SD cards are formatted using the Ricoh recommended SD card formatting tool. It can be found on the TSRC site. We found this corrected a variety of issues when using SD cards to update firmware.
              "Enjoy every sandwich."
              -- Warren Zevon
