Ricoh Aficio MP C2551AD Network Scan To Folder
  • Kayasoft
    • Apr 2025
    I use the RICOH Aficio MP C2551AD as a network printer at work. The device scans to the public folder on the network. But I wanted to use local network instead of public network. Device configuration for this purpose; Instead of the FTP protocol, which is a common network folder, I set it up to scan to the shared folder I created on the client computer with the Windows 10 operating system and the 1809 architecture included with the SMB protocol. . I never made it. I checked the network connection, the printer, and all settings on the client computer. Everything looks normal.
    The configuration settings are as follows;
    Registration Number: 00002
    Key Picture: file name
    Title
    Title 1: None
    Title 2: None
    Title 3: None
    Add to Favorites: Open
    Authentication Information
    User Code: Empty
    SMTP Authentication: Do Not Specify
    Folder Authentication: Specify Another Authentication Information Below:
    Login Username: xxxxxx (I'm sure I typed it correctly)
    Login Password: xxxxxx (I'm sure I typed it correctly)
    LDAP Authentication: Do Not Specify
    Available Functions
    Color Copy Mode Limitation: Limit Automatic Color Selection (Selected by default)
    Protection
    Use Name As: Destination (Selected by default)
    Protect Goal
    Protection element: Empty
    Protection Mode: Idle (Inactive)
    Email
    Email Address: Empty
    User Certificate Status: None
    User Certificate: Empty
    Encryption: Personalized setting (Selected by default)
    Folder
    Protocol: SMB
    Port # 21 (Written by default, inactive, cannot be changed)
    Connection Type: NDS (selected by default, inactive, cannot be changed)
    Server Name: Empty (Inactive, cannot be changed)
    Path: \\ xxx.xxx.xxx.xxx \ filename (I'm sure I typed it correctly)
    Add to group
    Group Details: Change (Enabled, not using)
    • 36685
    Re: Ricoh Aficio MP C2551AD Network Scan To Folder
    Have you checked to see if the C2551 has to proper firmware to support SMB v2/3, assuming it is available. It is necessary for SMB scan to folder on Windows 10. I have also found that SMB works best if you are using NetBIOS name and not IP address especially if you are on a domain. The OS security assumes that files arriving via SMB and sent directly to an IP address to be malicious content from outside the domain.
    • copier tech
      • 8093
      I agree as slim says I still have a few of these old models about & have needed to update the firmware on a few for users that insist on scanning via SMB.
      Usually happens after customer updates to Win 10 or even a routine Windows update.
      • dalewb74
        • Feb 2018
        • 1107
        have you checked under the network advanced sharing permissions are all set correctly? i have seen a windows update turn off something that needs to be on. looks like for the path you used the IP, have you tried it with the PC name?
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          I'm adding a third voice to updating the firmware to add SMB v.2.0/3.0 support.
          It looks as though the latest firmware will do this (I just checked the version numbers).
            • 36685
            Microsoft updates turn off SMBv1 support. You can turn it back on but the next update will turn it off again.
            • GIUBOSS
              • 1382
              momentarily disables the firewall and then also the antivirus. Check if it works and if it changes the authorizations inside them
