Hi there,
I'm wondering how you guys proceed in general when it comes to updating the firmware of a ricoh machine that is out in the field.
The reason I came up with this thread is because I always ask myself if there might be a better approach as I do it, because right now it's really time consuming.
- Question 1: Do you always update the firmware or just when there's a problem that can be fixed or a new function that will be added (e.g. smb)?
- Question 2: How do you prepare the files beforehand? Right now I download all the zip files from ricoh, name them accordingly, unzip and go through them and check if there's a newer firmware available. Then I check the text file that comes with it to see if there's a dependency noted, so that I do not oversee to update another firmware which is needed if I update it. Then I put it on the sd card in the romdata folder, name the folder e.g. Dxxx. With the newer machines there's a package, but I still check because a) I've heard sometimes there are older versions integrated, b) it does not contain all of the firmware as far as I know and c) because I still want to check each firmware if there's any dependency.
- Question 3: In what order do you update the firmware? Ricoh told me to do the system, then Networksupport and then Engine first and then all the other ones, each seperatly. Recently I've spend hours doing this on a 3003 machine because of the restart times of that machine and this doesn't even include the time preparing the files.
Thanks and happy updating!
Best regards,
Trommel
Best regards,
Trommel
