Factory mode MPC 307
  • crisinjomi
    • Feb 2019
    • 14
    Good afternoon mates.
    I am reading the MPC307 manual and I can't find how I can reset the machine to factory, to erase some applications that have been installed.
    Thank you.
  • zed255
    How'd ya manage that?
    • 1025
    Re: Factory mode MPC 307
    Ricoh does not use a factory reset like some other brands do. Apps can be removed and user tool settings can be reset to default. Whatever you do, do not perform the reset in SP mode 5-801-01 'all clear'! It is not what you think and can cause you grief.
      • 22801
      I am reading the MPC307 manual and I can't find how I can reset the machine to factory, to erase some applications that have been installed. Thank you.
      IF you have the birth cert for the machine do an "all clear"
      BUT ONLY -=IF=- YOU HAVE THE B.C.
      • crisinjomi
        • Feb 2019
        • 14
        The problem is that a Ricoh application called NDD was installed, and after uninstalling it, SC637 causes me to run into problems.
        Everything has happened since the application was uninstalled
          • 36689
          The same is true for SP 5-801-002. This deletes all the customized settings that were made at the factory and in the field by previous techs.
            • 36689
            To my knowledge, there is no NDD application produced by Ricoh. Perhaps you are referring to nddPrint. It may not have been uninstalled correctly. You might need to contact their support people. https://www.nddprint.com/
            • HitMan
              • Aug 2015
              • 170
              Thank you.
              Have you had a look in user tools to see if it's installed on an sd card? What about formatting the hdd.
              I need to ask if your profile picture is real?
              Sent from my SM-G930F using Tapatalk
              • keithxxiii
                Just a tech
                • Nov 2014
                • 469
                Check the SP5401 if there are any remnants of the application installed on SDK.
                If possible, uninstall the Java and restart the machine. It will reinstall itself once rebooted.
                Aye! Cut the crap
                • Zaxxon
                  • 608
                  Update Java, Update full fw package, restart, wait 10-15 minutes and then delete NDD. Worked for me.
                  Please start you post with brand, model, problem.
                  • crisinjomi
                    • Feb 2019
                    • 14
                    Well the solution has been to return all SPs that were modified to their default value and in user tools disable use of print volume and user authentication.
                    Thanks for your help.
                    • pakobernal
                      • May 2012
                      • 46
                      Hi friend, I have a imc300 with ndd installed, How I can uninstall?
                      • Elmo
                        • Feb 2010
                        • 541
                        in user tools Login as admin
                        go to extended features if the app is in the list uninstall
                        Log back in as admin in system settings - admin tools go to erase all memory
                        I Used To Live To Fix Things Now i Fix Things To Live
                        • Wow_copier
                          • Feb 2020
                          • 6
                          Hey I too had an issue with a Ricoh MP-C307 came in with Admin & Supervisor passwords all changed & I have not figured out how to reset the passwords or reset the machine to factory defaults. I already did a SP5-801-01 memory "Clear All" before reading this thread & it did give me a few issues but still no access to change the admin password. Anyone have a quick solution for me to wipe this machines so I can sell it & move on to the next problem child..... My warehouse is full of them... Thanks -JB
                            • 36689
                            You need to run SP5846-046 to reset Admin and supervisor credentials to factory default. Is only available in Factory SP mode, https://www.copytechnet.com/forum/te...pc4504ex-reset
