mp 6503 with j003 issue
  • totoro
    • 568
    Hey guys, I have a mp6503 with an intermittent J003 problem. No toner dropping from dev unit and meter at 700k. Have gone in and switched T1 and T2 feed units as customer says they can run their jobs from T2 and then T2 runs and T1 jams again. Went in there and put a new feed unit in T1 and ran 500 sheets through no problems. Customer called back with same issue. What am I missing?
    Totoro
  • FrohnB
    • Jul 2017
    • 1919
    Re: mp 6503 with j003 issue
    J003 is a "non-feed" jam, paper not making it out of the tray. In Most cases the customer loads the paper crappy, or there is paper caught behind the tray not allowing the coupler to engage properly.
    End fences and side fences in correct position and not broken?
    If paper is loaded fine, and you already replaced feed unit, then you could be looking at a bad feed clutch.
    Omertà
    • totoro
      • 568
      no paper behind tray, end and side fences look fine. Paper is loaded good. I thought this model used motors for feeding , not clutches. I know that there is a feed motor on the feed unit itself, but i'll look into that. thanx
      Totoro
      • luca72
        • Oct 2017
        • 1673
        hello, those capacious drawers require a lot of attention and some practice to be loaded correctly, I say this because I often find in the middle of the 3,4 stack, the sheets are really bad, however you say you have replaced both pick up stations, were they new? I ask you because because they are very expensive, many dismantle them from used / withdrawn machines, which could be badly defective at times (it happened to me) try to ask the customer if he happened to witness a jam directly, if hit he heard a loud "gnhrrrrrrrrr" sound sorry i don't know how to make the unidirectional stuck noises well, since they are very interchangeable between various martini models, surely j003 concerns the lack of grip of the sheet.
        "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
        • totoro
          • 568
          Paper in tray is being loaded correctly. Paper feed unit was new. There is an adj for sep roller pressure that I have never used. I may try that. could this be a problem with the try lift? Tray seems to be level when it is down all the way. Lift motor? Lift wires? bottom tray?
          Totoro
          • luca72
            • Oct 2017
            • 1673
            at this point, it would very well be a lifting problem, there are some parts that can break in the drawer / lifting unit, fortunately for you they are quite easy to locate on sight, I suggest you remove the drawer and inspect the mechanism lift
            • totoro
              • 568
              will be back there soon and let you know. thanx
              Totoro
              • bojans
                • 1313
                Hi,
                I had same problem last days. After changing separation rollers, no more problems.
                RICOH MP 7503 J003
                  • 36694
                  Originally posted by bojans
                  Hi,
                  RICOH MP 7503 J003
                  If you only changed the separation roller, you will be back.
                  • copier tech
                    • 8095
                    If you ran 500 without a jam then the customer loads paper & it jams what does that tell you!?
                    • totoro
                      • 568
                      I have watched customer load paper in the tray and they do it better than I do. It has to be some mechanical problem that i'm missing, but thanx for the imput.
                      Totoro
                      • luca72
                        • Oct 2017
                        • 1673
                        hahahahaha, you made me lie down, I have a colleague who does this !, change the parts individually, my boss and I always take it for a ass!😂😂😂
                        • skinnyb
                          • Jul 2008
                          • 291
                          Truth. Always replace the set, or it WILL bite you in the @$$
                          Sent from my LM-V405 using Tapatalk
                            • 36694
                            What you are missing is the rest of the 3 roller paper feed system. It is recommended the all three rollers be replaced new at the same time.
                            In normal operation the friction between the feed roller and separation (reverse) roller is greater than that of the torque limiter. This allows the feed roller to drive the separation roller in the feed direction. When either are worn the separation roller can slip against the fed roller and turn in the reverse direction. This causes the jam. Replacing just the separation roller usually corrects the problem for a couples of weeks at most.
                            • copier tech
                              • 8095
