mp c307, won't see blk toner
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Machine is practically new. First black toner bottle change, gives setting error. First thing was to try another bottle. I then ordered the board that detects the bottles are set and changed it. Still have fault. In talking to Ricoh, I mentioned that the shutter on the bottle is not being closed when I remove it. He had me replace the toner delivery system, or as he called them, the "caps" the bottle sets in. I changed all four. Shutter still does not close and fault is still on machine. I tried removing all bottles, doing an engine clear, and reinserting the bottles. Did not work. I spoke with Lee at Hytec and his last suggestion was to replace the nv ramm. Should I order one, or have I missed something simple
  • FrohnB
    • Jul 2017
    • 1919
    Re: mp c307, won't see blk toner
    Those freaking Tech support guys "Might be NVRAM". SMH.
    What part numbers for the 4 individual "hoppers" (I'm assuming D1963302 and 3 - D1963303's?). If these are what you replaced it won't help.
    Where the toner bottles "seat into" is ONE piece that has all 4 slots for the toners D1963301 or D2963300, This is where the problem resides.
    The individual hoppers that I assume you replaced attach to this.
    Check that the little white "hooks" that engage the shutter on the bottle are in the same position and have the tiny springs attached --> I'm thinking this is your issue, because the biggest symptom for this is shutter not closing when you pull bottle out. You can view them from the front of the machine. Shine a light into the toner slot and look all the way back there (may have to vacuum clean to get a good look), and you will see the little white hooks.
    Omertà
    • Imprestik
      • Aug 2012
      • 296
      Yup, had this many times before and as mentioned above your toner hopper is stuffed. Sometimes you can get away with the white hooks being able to get clicked back into place with a spring hook.
      Just remove the exit tray, carefully remove the lazer unit while its still connected to the ribbon cable and shine a torch in. You will see the difference straight away if one of the white clips are bent/broken. Just compare it with the cyan one.
      Ultimately a new toner hopper and RFID will be required.
      Absolutely bitch of a job, take your time and leave yourself 4 hours to do it the first time.
      Lost count of how many of these I have done.......
      • fixthecopier
        ALIEN OVERLORD
        • 4714
        Thanks for the quick replies. The part that the bottle seats into, with the white clips is what I replaces. One of the clips was broke, but with the new unit in, shutter on bottle still won't close. Since posting, I contacted Ricoh again and they said it would be the BICU, before it would be the RAMM. Shop that said it was RAMM does our board repairs and are really good. And my gut tells me it is neither of those.
        • copier tech
          • 8093
          I agree, seen this on a 305 sounds like the 307/407 use the same hopper system.
          If you look the bottle doesn't go all the way in hence the "missing toner" message.
          • fixthecopier
            ALIEN OVERLORD
            • 4714
            I will go with the expertise of people who still do this job in the field. Looks like I'll be taking her apart again in the morning for a closer look.
            • FrohnB
              • Jul 2017
              • 1919
              If it’s still keeping the shutter open, it’s something “mechanical”, not the BICU.
              There is a bulletin for the c306 that says the toner bottle rotation gear could be out of place from the factory (might apply to c307). Easy way to check this is to try and spin the toner bottle by hand. If you can spin it counter-clockwise that gear is out of position. If that gear is in the correct position, the toner bottle will NOT rotate either way.
              Also has a bulletin for the toner bottle chips being unable to move side to side or up and down, causing toner not set message. Easy way to check is to look at the chip and rotate the bottle (out of the machine) The chip should slide side to side and up and down in its holder.
              EDIT: Make double sure that the toner housing you replaced is completely “seated”, I know they’re a bitch to get in and out.
              Omertà
              • Polarbear
                • Feb 2012
                • 1070
                +1 on the previous posts regarding the issue being mechanical.
                You need to sus out why the bottle is stopping early, as the chip needs to seat on the contacts on the BRB board, else "toner not set correctly" will result.
                Maybe remove the cover over the laser units, and the laser units. This should give you a good view of what is going on when the bottle goes in.
                Press the GREEN button!!
                • copier tech
                  • 8093
                  This is the best way to gain access.
                  Both lasers out look for a white sprung loaded arm compare the position of this to the other toner check its in the same position.
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Hope this may help really common
                    Regards Mark
                    • Klydon
                      • Mar 2009
                      • 242
                      Everyone is pretty much all over this being a mechanical issue and they are most likely right because it happens a fair amount. I have had a lot of luck using a spring hook taped to a long screw driver so I can reach back and yank the white clip back into place (typically it is in the "closed" position with the bottle out and won't let the bottle go all the way in).
                      Another issue I have had at least twice is carefully look at the contacts where the bottle chip matches up. The "spring" wires are typically ok (maybe dirty, but easy enough to clean), but the two connection points on the post, I have had issues with. In both cases, one of the wire connection points was pushed down off the post. You cant really fix that and the sensor board has to be replaced unfortunately. (Not fun to replace, but then anything to do with hoppers and such on this machine isn't fun anyway).
                      As far as the comments about tech support saying replace the NVRAM, I really wish tech support would train their people better. NVRAM seems to be some boogie man item to say as a last act of desperation to fix something. It is extremely rare that NVRAM is actually the issue and a lot of times there are other symptoms (like going into service mode and seeing data scrambled, etc). I talked to an engineer one time about NVRAM and he told me it is extremely rare it is an issue.
