SC-569
  • ksp
    • Oct 2013
    • 22
    [Error Code] SC-569
    Customer has a Ricoh MP-C6003 it has been a real good machine but has thrown up a SC-569 code. I noticed that the ENCODER plate was 180degrees off. so I turned the gear that drives it a turn to bring it back to hm position. A couple hours later I get a call saying that the same code was back. I then went back and replaced the sensor (AW02 0190) for the encoder plate. 5 hrs later they call again with the same code. This code is for the pressure release from UFR to LFR when not in use, by way of eccentric cams so that there isn't pressure on the UFR sleeve all the time. The book only gives 3 options: 1- replace the motor, 2- replace the sensor, 3- replace the fuser unit.
    If anybody has ran into this before I sure could use some input. Thanx
  • skinnyb
    • Jul 2008
    • 291
    Re: SC-569
    There is a 1 way in the Fuser drive unit that is failing. It slips and keeps the pressure from applying and releasing properly. I generally order the drive unit to be safe, it's kinda a pain to remove.
    Sent from my LM-V405 using Tapatalk
      • 36694
      Re: SC-569
      Paper exit/Pressure release motor
      • ksp
        • Oct 2013
        • 22
        Re: SC-569
        Do you have the P\N for the drive unit?
        • hanspeter75
          • Mar 2010
          • 37
          Re: SC-569
          d1751357
          • farhad
            • Apr 2020
            • 40
            Re: SC-569
            check you elevator sensor for presure under fusing
