Ricoh MP C3003 iding noise
  • thurmmy
    • Aug 2016
    • 102
    I have a MP C3003 that was a lease return, at the new customers office during idling, or rather throughout the day, periodically the copier will cycle through making a very audible ticking noise mainly from the right side. I thought that the problem was the fuser, I replaced it but still the same. Has anyone encountered these symptoms?
  • anothertech
    • 1756
    Re: Ricoh MP C3003 iding noise
    Go in to service mode and run the motors in I/O mode, you should be able to narrow it down.
    • Notrons
      • Apr 2016
      • 69
      Has any of the developer units been replace lately? I replace one on an MP C4504, that has this knocking mechanism that keeps toner from building up around the toner intake port. Not sure if the 03 modals have the same mechanism with there newer Dev units, worth a shot.
      • thurmmy
        • Aug 2016
        • 102
        Thanks for the reply. The copier has only 21k on it, so no, the dev. units have not been replaced. Also all firmware is up to date.
        • FrohnB
          • Jul 2017
          • 1919
          Omertà
          • thurmmy
            • Aug 2016
            • 102
            Yes, replaced fuser with new one. That was my thinking that it was in PR bearings as that is what it sounds like. The noise not come from collection bottle area. It occurs as in a periodic fuser warm up or energy mode. You can also hear it when opening/closing front or side door etc. I shall be going over there this afternoon an try output modes as anothertech suggested to see if I can narrow it down a bit. I see a special note on the output for fuser drive in which you remove fuser first. Thanks.
            • menosmola
              • Apr 2014
              • 95
              Check the metal spikes in transfer roller, if there is any rise spike, when the paper passes it makes noise....
              • copier tech
                • 8097
                Run output checks in SP mode, drum, dev, transfer unit, fuser etc this will help you narrow down the issue.
                • tsbservice
                  Field tech
                  • 7906
                  Don't know Ricoh but exit/fuser fan may kick in when fuser rotates in idle. Unbalanced fan fins may catch fan cage.
                  • FrohnB
                    • Jul 2017
                    • 1919
                    Omertà
                    • Mr Magic
                      • Jan 2020
                      • 29
                      ...also, as soon as you hear it - push the right-hand door and see if it goes!
                      • luca72
                        • Oct 2017
                        • 1676
                        there, ours 3003, did all that ticking .. LOL, you have a few customers here who ask me, I say that it is the noise of the thermal expansion of some internal structures, instead it is the bearing ball-pressure roller copling.
                        if you want to try it with "sp output check" remove the waste toner bottle, so the heater does not activate, if not cremate the sleeve
                        "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
                        • thurmmy
                          • Aug 2016
                          • 102
                          I have not been able to return there to follow up yet, but that is a new fuser from Hytec in it and I am confident of it. I still need to do the output checks on it. But still, right after I put the fuser in it seemed quiet while I was there. It was a couple days after that the customer called me back and said the noise is still there. So I suppose it could be the fuser yet. I have the original fuser here and can dig into it. Thanks
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            If in standby I think the 03's have a silent mode in user tools {think}
                            Regards Mark
                            • skinnyb
                              • Jul 2008
                              • 291
                              If it's a rebuild there is a chance they didn't put quite enough lube on the pressure roller bearings. I would pull apart and inspect, lube the bearings if they are dry and the gears too. I slather lube (I use Krytox) all over the gears, keeps them from eating themselves over time. Also you can go into service mode and cut down the idle rotation time and frequency (can't remember exact the SP Mode). Mostly it's a non issue unless someone sits beside the machine and hears it all day long...
                              Sent from my LM-V405 using Tapatalk
