JAVA FIRMWARE VERSION
  • hosennet
    • Mar 2007
    • 145
    Hi All
    HOW TO UPDATE Firmware Java VM v12 std Ver.12.25.05 D2415579D TO Ver.12.69.00 D2415579X
    Thanks First
    • 36733
    Re: JAVA FIRMWARE VERSION
    Normally you follow the instructions in the Verup_tools PDF that is in the document folder after you extract the the downloaded VM update.
    • hosennet
      • Mar 2007
      • 145
      Thanks slimslob
      Yes update to SDK 1030800 Ver.12.69.00
      But the Java VM v12 std Ver.12.25.05 D2415579D NO Change
      • copier tech
        • 8096
        Originally posted by hosennet
        Thanks slimslob
        [ATTACH=CONFIG]45709[/ATTACH] [ATTACH=CONFIG]45710[/ATTACH]
        Update your main package firmware first then try the JAVA again.
        • hosennet
          • Mar 2007
          • 145
          Try It
          • hosennet
            • Mar 2007
            • 145
            What's relation about CVM package and java firmware for MP C4504
            • ridgemill
              • Sep 2017
              • 180
              Are you using D2415579X_upd or D2415579X_edc?
              The best way, we find, is:
              Download D2415579X_upd
              Run the self-extractor
              Run D2415579X_upd.exe
              Navigate to the first sdk folder
              Copy folder and contents to a blank SD card
              Use the service SD slot to update
              Turn on with SD card in slot and wait for confirmation
              • hosennet
                • Mar 2007
                • 145
                Answer: D2415579X
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  Answer: D2415579X
                  AND RIGHT THERE IS THE DUMBEST ANSWER EVER..!!!!
                  He asked if you were using _upd or _edc
                  • hosennet
                    • Mar 2007
                    • 145
                    Answer: D2415579X_upd
                    • copier tech
                      • 8096
                      Here's a document that may help. It's for the non SOP model but the process is the same.
                      Ricoh JAVA Update.pdf
