MP C4503 Finisher error
  • iscott
    • Mar 2010
    • 344
    Works fine with paper from tray 1 long side first. If you sent any other orientation letterR Legal or 11x17 you get the message "Remove paper from shift tray" But there is no paper in the shift tray. The message pops up as soon as the paper ejects into the shift tray. Firmware is up o date and have swapped finishers so that's not it.
    • 37231
    Re: MP C4503 Finisher error
    Which finisher? SR3140, SR 3150, SR3160, SR3170 or the internal SR3130?
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      I was about to type the exact same response Slim.
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        If it IS an SR3140 check the mylars on the eject fingers.
        They bend up and interfere with the correct exit of the paper onto the shift tray.
        • copier tech
          • 8130
          He has swapped the finisher!
          Sounds like an exit sensor delay but need to know what finisher first.
          • iscott
            • Mar 2010
            • 344
            The Finisher is an SR3140
            I doubt that its the finisher since we swapped it with another SR3140, and got the same message.
            One change. It does not error out when 8-1/2x11 goes through in the letter R position.
            • davel
              • Oct 2011
              • 1093
              Was the other finisher working before.
              • iscott
                • Mar 2010
                • 344
                Yes.
                • copier tech
                  • 8130
                  If you get the same issue with two different finishers what about with no finisher installed do you get any errors or jams?
                  • mrwho
                    Major Asshole!
                    • 4299
                    I know you said you tried with another finisher, but nevertheless check the feeler that sits between the sponge rollers, it might be stuck (in both finishers)
                    Mascan42
                    Ibid
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      ^ This and also check those mylars....nothing to say that they aren't deformed on both finishers.
                      It's a stupid design.
                      • anothertech
                        • 1759
                        Check to make sure the flag is going into the sensor that senses the tray lower limit, make sure the tray is not crooked and jacked up on the rear side. Also the harness is a little too short and sometimes gets pulled part way out of the sensor.
                        • fshead
                          • 2360
                          id swap in a known working bridge unit..
                          just to be sure
                          • frere
                            • Jun 2020
                            • 12
                            The message is it " Remove paper from shift tray because it's full " or remove a paper jam.
                            Try to exit the paper on the superior tray to see if it works.
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              Look at the paper height sensor actuator in the exit assembly you move out the way when installing Bridge unit
                              Regards Mark
