Ricoh PRO 8120S has an error code SC401-01
  • AL parts
    • Jun 2019
    • 61
    After the customer replaces the OPC DRUM, this code will be displayed,
    I checked the maintenance manual and showed that this code is not related to OPC DRUM
    If you have encountered this code, please give me suggestions, thank you!
    www.gzanling.com
  • mrwho
    Major Asshole!
    • 4299
    Re: Ricoh PRO 8120S has an error code SC401-01
    I had a similar problem (posted here). The problem is now solved, but I can't remember what was done to solve it (and I didn't post it in the forum - need to dig in my documentations to try and remember what was done and update the thread). Anyway lots of good hints there.
    Mascan42
    Ibid
    • mrwho
      Major Asshole!
      • 4299
      Question: If you go to the logging data, are there any other codes logged besides 401-01?
      Mascan42
      Ibid
        • 36733
        This code is directly related to the drum replacement. SC401-01 is a Development gamma low error. The entire PCDU has to be pulled in order to replace the OPC drum. The development unit is the D part of the PCDU. In replacing the drum something happened that affected the development unit.
        • mrwho
          Major Asshole!
          • 4299
          Specially if the customer replaced it...
          Mascan42
          Ibid
          • AL parts
            • Jun 2019
            • 61
            No other code,
            It's normal before replacing OPC DRUM
            This code comes out after replacing the OPC DRUM
            www.gzanling.com
            • AL parts
              • Jun 2019
              • 61
              This question seems to be very common, I have almost ten customers asking the same question
              www.gzanling.com
              • mrwho
                Major Asshole!
                • 4299
                Shouldn't be normal - I never had that happen to me. Maybe the operators weren't given the correct procedure to replace the drum?
                Does it happen when you replace the drum?
                Maybe you should ask the customer to replace it while you supervise and make sure he's doing it correctly...
                Mascan42
                Ibid
                • CopyBats
                  • Aug 2011
                  • 133
                  If it works, don't touch it.
                  • tsbservice
                    Field tech
                    • 7906
                    OPC drum OEM?
                    • AL parts
                      • Jun 2019
                      • 61
                      OPC drum OEM?
                      OPC is a compatible product from South Korea, and this factory produces OPC for Ricoh.
                      We have rigorously tested, life and print quality,
                      No error code appeared during the test
                      www.gzanling.com
                      • anothertech
                        • 1756
                        Oh boy, I think we are on to something here. Might you try an actual Ricoh Drum?
                        • Notrons
                          • Apr 2016
                          • 69
                          Wouldn't old worn out developer, also cause this SC?
                          • mrwho
                            Major Asshole!
                            • 4299
                            So you tell us you have lots of customers complaining about that problem, and it never ocurred to you that maybe the drums are the cause?
                            Mascan42
                            Ibid
                            • AL parts
                              • Jun 2019
                              • 61
                              Recently, we tested many OPC drum that had previously appeared codes, and no codes appeared on our copiers. We are still discussing issues with customers, each machine is in a different state.
                              www.gzanling.com
