RICOH MPC3003
  • tullio
    • Feb 2012
    • 268
    RICOH MPC3003
    How do you disassemble to replace the developer? On ricoh mp c3003 urgent thanks
  • 8T2
    • Aug 2015
    • 257
    Re: RICOH MPC3003
    Need to replace complete development unit. I tried opening one of those Dev units once to remove lumps and fix white lines. Broke all the clips trying to get it open because they are not designed to be serviceable. No part number for seperate developer that I know of, I suspect MPC2800 developer may work but won't be spending my boss's money on that experiment
    Sent from my WAS-LX1 using Tapatalk
    • mikadonovan
      • May 2008
      • 2936
      Re: RICOH MPC3003
      Replacing the developer in these is nearly an exercise in futility. I have managed to get all the old developer out of a C6003 unit, and filled it with 350g of c3300 dev with no initial image problems. The problem is, the spill plate and augers get caked with stuff over a period of time, and these chunks fall off and get stuck at the doctor blade causing white lines, which is why I changed it to begin with. The only way to make this work, in my opinion, is to completely disassemble the entire dev unit to it's component pieces and scrape all the caked residue off the internal components. You may not even be able to get it all out, which means failure can happen immediately after you just spent hours to remedy the situation. This new dev unit design sucks.
      NEVER ASSUME ANYTHING
      • fshead
        • 2356
        Re: RICOH MPC3003
        i have them apart and just need to be gentle as tabs break easily..
        I have vacuumed them out after dumping developer mix and try to clean any buildup inside.
        It depends on how long it ran with clumps and such...
        • skinnyb
          • Jul 2008
          • 291
          Re: RICOH MPC3003
          Replace the whole unit. Done and done. I don't mess with disassembly as it is a total crap shoot whether it works or not. I have noticed they seem to last longer than they used to, at first we were replacing lots of them..
          Sent from my LM-V405 using Tapatalk
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Re: RICOH MPC3003
            Agreed they are cheap and the gears don't last just replace what and when the machine needs
            Regards Mark
