MP 7503 SC 300
  • Hoosierdaddy
    • Oct 2016
    • 181
    MP 7503 SC 300
    I have replaced the Screen Grid and the Cor. Wire. Plus Drum and Developer recently. Is the Power Pack the next move? Or has anyone had this issue on these. Machine has 1.4 Million on it.
    Thx Hoosierdaddy
    • 36689
    Re: MP 7503 SC 300
    Sounds to me like that new corona wire may have broken. Happens with the martini.
    • Codex
      • May 2008
      • 693
      Re: MP 7503 SC 300
      I recommend in this machines to disassemble completely the charge unit and clean everything.. Before changing wire and grid. Had two mp7502 with intermittent sc300... Turned out to be a kind of oil or grease under the grid.. Maybe vaporized silicon from the cleaning web?...
      Inviato dal mio SM-G935F utilizzando Tapatalk
      Memento Audere Semper
      • Gab
        • Aug 2015
        • 653
        Re: MP 7503 SC 300
        clean corona thoroughly
        • skinnyb
          • Jul 2008
          • 291
          Re: MP 7503 SC 300
          I replace assembly when I do a PM. My eyes are too old to be able to see that little bitty wire. Especially with that kind of mileage I would anyway.
          Sent from my LM-V405 using Tapatalk
            • 36689
            Re: MP 7503 SC 300
            The insulator blocks at the ends of the corona can develop hair line cracks that will collect toner haze and allow wire to arc to the shell. I also have had machines with a bad connection block on the frame that arcs to ground. If you get SC300 during copying and a solid black background band check the drum shaft continuity to ground. There is a ball bearing in the bracket that holds drum shaft that is supposed to be conductive. With age it loses its conductivity.
            • luca72
              • Oct 2017
              • 1673
              Re: MP 7503 SC 300
              Thx Hoosierdaddy
              hi, sc300 is a classic for the corona unit based machines, generally when I rebuild that part, I replace everything, blocks, wire, covers, grille, etc, only the metal part remains.
              however you can do a test: take white correcting liquid (I don't know what it's called in your area) and paint both blocks well with the brush, both inside and outside, mostly the internal one, so you can better determine if have losses ... old school!
              "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
              • tjvincent
                • 280
                Re: MP 7503 SC 300
                Is the machine blowing toner on the charge unit ?
                Maybe the dev unit is blowing toner ?
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  Re: MP 7503 SC 300
                  Same here....too many years of rewiring Canon corona AND GRIDS......now I just replace the entire charge unit.
                  • skinnyb
                    • Jul 2008
                    • 291
                    Re: MP 7503 SC 300
                    Absolutely. Started on Canon, restrung those wires for years starting with the NP analog then the newer image Runner digital. And the wire on a spool, not even pre measured. Those were the days. My eyes and coordination don't do that well anymore... And the assembly is dirt cheap in the grand scheme of things. I keep the wire and grid from the PM kit for an emergency. I have been known to clean up an assembly and change just the grid in an emergency but I know better than to try the wire anymore...
                    • zoor
                      • Jul 2019
                      • 24
                      Re: MP 7503 SC 300
                      Thx Hoosierdaddy
                      Replace the front and end blocks with covers , clean the entire crown housing with glass cleaner liquid (or other that contains ammonia )
                      • mga
                        Copier Technician
                        • Dec 2010
                        • 1393
                        Re: MP 7503 SC 300
                        Thx Hoosierdaddy
                        Try replacing complete corona assy
                        Regards Mark
                        • Hoosierdaddy
                          • Oct 2016
                          • 181
                          Re: MP 7503 SC 300
                          Went ahead and replaced entire assembly. Working like a charm. Thanks everyone for the insite.
                          Hoosierdaddy
