MP C307 has blank screen
  • Chummy
    • 8
    Can anyone help with a MP C307 that has a blank screen with only the blue power light on in the top right of the control panel ? The fuser warms up but the machine won't print, copy or scan. Any suggestions.
  • 8T2
    • Aug 2015
    • 257
    Re: MP C307 has blank screen
    I'd try accessing Web Image Monitor to look for any alerts or error codes, but I suspect it's a faulty controller
    Sent from my WAS-LX1 using Tapatalk
    • TonerMunkeh
      Professional Moron
      • 3869
      Could also be the ops panel main board.
      Hit it.
      • FrohnB
        • Jul 2017
        • 1919
        I agree with TonerMunkeh.
        Usually it's the Op Panel that has crapped out. We normally send ours into Hytec for repair as this is cheaper than buying a new one.
        If you have a good donor machine, I would try swapping the op panel to see if that is indeed what it is, and if that doesn't solve it, then you may be looking at a controller.
        Omertà
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          +1
          Regards Mark
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Here you go
            Regards Mark
            • Chummy
              • 8
              Thanks for the info given so far. I will be returning to the machine later this week and will use the info given for further investigations. Thanks again.
              • Chummy
                • 8
                Swapped Op Panel from donar machine, all working again. Many thanks !
                • copier tech
                  • 8097
                  Thanks for the update.
                  Interesting that this stopped the machine from printing.
