airprint c3003
  • Mark Bbb
    • Jun 2012
    • 1662
    airprint c3003
    Hoi,
    We have Airprint active in WIM, but it is not working.
    We presume that the Airprint signals go via the wireless router and not via the c3003 itself.
    Does the Airprint certificate needs to be filled in? If yes, how?
    First we installed the "Ricoh Smart Device Connector" app on the Iphone.
    Then it asked for the QR code (which we don't know how to print it) OR to fill in this info:
    the IP address (of the c3003), shared name, domain name, log in's.
    Do they mean the log in's from the router?
    Thank you (again!) for helping us out here.
  • Gift
    • Mar 2011
    • 2444
    Re: airprint c3003
    perhaps this will help:
    Installing Ricoh device certificate - YouTube
    • Mark Bbb
      • Jun 2012
      • 1662
      Re: airprint c3003
      Originally posted by Gift
      Many thanks, Gift!
      Is this certificate also needed on a imc2000?
      • Gift
        • Mar 2011
        • 2444
        Re: airprint c3003
        Originally posted by Mark Bbb
        Many thanks, Gift!
        I haven't had to enable airprint with the IMC series yet but I'd assume it's the same set-up procedure
        • copier tech
          • 8097
          Re: airprint c3003
          Hoi,
          There was a firmware fix for AirPrint on this model, update to the latest package & try again.
          For the smart device connector app add the copier via ip address you'll find this a lot more reliable.
          • Gift
            • Mar 2011
            • 2444
            Re: airprint c3003
            I think this QR code feature for the app was introduced with the MPC3004 series. This app also has nothing to do with airprint, that's a native feature for apple mobile devices.
            • copier tech
              • 8097
              Re: airprint c3003
              This is correct, the QR code is an app for models with the smart operation panel.
              • Mark Bbb
                • Jun 2012
                • 1662
                Re: airprint c3003
                I followed all the steps in the link, but:
                "the safety certificate of the server isn't trusted by the operating system of your computer. Maybe caused by a wrong config or a hacker. Continue?"
                I pressed continue...
                I presume that this is not an issue?
                • Gift
                  • Mar 2011
                  • 2444
                  Re: airprint c3003
                  Yeah that might show up since it's not a validated, obtained certificate.
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    Re: airprint c3003
                    Thanks, Gift.
                    Is this certificate originally for free or not?
                    And has the imc2000 also such a certificate, or is it for this model already been signed?
                    Perhaps there is a Ricoh bulletin concerning this matter?
                    I'm posting a lot of questions, i know. But you must know that with a Brother these are no issues at all;
                    it installs itself automatically...
                    • copier tech
                      • 8097
                      Re: airprint c3003
                      Thanks, Gift.
                      To rewrite the certificate try running SP5870-003 then 001 and reboot the device, this should then allow you to use Airprint, if still no luck then try the update certificate method see attached pdf.
                      C1 METIS AirPrint.pdf
                        • 36734
                        Re: airprint c3003
                        The SOP is available for the Cxx03 models as an option.
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          Re: airprint c3003
                          Hoi,
                          Hope this helps also make sure package firmware is up to date and the apple device needs to be up to date
                          Regards Mark
                            • 36734
                            Re: airprint c3003
                            If the C3003 has a SOP the QR code is displayed on the panel. If it does not have a SOP then you do not need the "Ricoh Smart Device Connector" app. Scanning the QR code gives the "Ricoh Smart Device Connector" app on the Iphone the needed connection information in order for the app to connect to the customer's WiFi.
                            • copier tech
                              • 8097
                              Re: airprint c3003
                              Yes, as I said on the smart operation panels.
                              Poster didnt state it was a Zsp model.
