MPC 307 bad multiple prints / copies
  • dave w
    • Jun 2015
    • 230
    Im looking for advice as I have a deadline of next Monday to fix due to the Covid Furlough working times I have ( only 2 days a week, Mondays & Wednesdays) so my last opportunity to crack this case is next Monday due to me being off until next year and I'm the only copier tech in the company ( small dealer)#Dont want the customer to wait until next year for a fix
    had one opportunity so far to investigate
    I have a MPC 307 that is not giving perfect multiple copies or prints
    please see attached , the quality is a separate issue as only happened after I fitted a new ITB & TRANSFER/SEPARATION UNIT: [ K pcu on order ]
    a single copy or print is fine - more than one sheet and the image moves
    No SC Codes
    all firmware has been updated
    SP mode adj were made after ITB was fitted
    SP1-001-031
    SP2-111-004
    Is this a obvious issue that I'm missing?
    Thanks in advance
    • 36694
    Re: MPC 307 bad multiple prints / copies
    My guess would be that the registration roller has not stopped before the next sheet gets to it.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      SP1-001-031
      SP2-111-004
      Thanks in advance
      Why did you so these adjustments you don't need to do this when you replace the transfer unit I would refit old parts if can still be used clean I'd sensors try 1st in user tools registration adjustment if that fails do force line adjustment incorrect order
      [/QUOTE]
      Regards Mark
      • dave w
        • Jun 2015
        • 230
        SP1-001-031
        SP2-111-004
        Thanks in advance
        [/QUOTE]
        • dave w
          • Jun 2015
          • 230
          Hi slimslob
          Thats my way of thinking, A timing issue.
          Its not one color thats affected all are drifting . I did think the paper transfer roller felt abit stiff and maybe thats the area I should concentrate on (dont have another machine to check against)
          Will have a go on Monday
          Many thanks
          Dave
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            [/QUOTE]
            Sorry you are correct I have fitted hundreds the only thing I do for itb is SP3-701-093 to 1 then reboot
            Regards Mark
            • ccfc87
              • Feb 2014
              • 18
              Originally posted by dave w
              Hi slimslob
              Many thanks
              Dave
              How did you get on with this problem?
              • dave w
                • Jun 2015
                • 230
                UPDATE
                back in the office today -and we have success!
                It was the registration clutch – was a total mission to replace and def a workshop job
                Thanks all for the help
                Dave Whidborne
                that's one problem sorted now another issue has risen it ugly head
                I was getting real washy blacks - under investigation I removed the K pcu and right at the back I was presented with a spring that was damaged. how ?
                now the joy of getting this right.
                anybody else had this joy and second do you think this is a black problem?
                thanks in advance
                Dave
                • marvin-vegan
                  Product specialst support
                  • Jan 2021
                  • 46
                  thanks in advance
                  Dave
                  Hi Dave,
                  got similar issue. After replacing of ITB - when removing belt out of machine, it was stucked. When released, spring was damaged. This spring transfers the current from HVPS board to ITB transfer roller (for black drum). It has to be curled again with the right shape or get another one. But the replacement is very complicated, nearly impossible on site. If you have proper tools and skilful hands, you can kind of recreate the original loop so the spring will again touch the counterpart on the ITB. Only then the current transfers correctly and black is rich again. Needs time and tiny hands/fingers.
                  • dave w
                    • Jun 2015
                    • 230
                    Originally posted by marvin-vegan
                    Hi Dave,
                    [ATTACH=CONFIG]47825[/ATTACH]
                    [ATTACH=CONFIG]47823[/ATTACH]
                    [ATTACH=CONFIG]47824[/ATTACH]
                    AHH YES!
                    Bang on what has happened - I was issued a new belt that was faulty.
                    It seemed to go in ok but was difficult to remove, I noticed the tension mech was faulty on the belt and im sure thats what messed up the spring.
                    same print out.
                    We have sourced another machine for the customer to keep and now I have time in the workshop to strip down and see what part is needed, difficult to see on the parts manual if its just a spring or a modual.
                    I have the time and good finger dexterity its just my eye sight that is letting me down now! lol
                    wish me luck
                    Thanks again
