Firmware Upgrade Ricoh MP C3502
  • craigp
    • Jan 2018
    • 34
    Hey guys,
    I just picked up a used MP C3502 and I do not think it has the ability to upgrade firmwares. When I go to the Downloads page on Ricoh Aficio MP C3002/C3002G/C3502/C3502G Downloads | Ricoh Global I do not see a way to update the firmware on the Machine.
    I do have the ability to go to firmware page and update it but where can I find the actual files for an update?
    • 36733
    Re: Firmware Upgrade Ricoh MP C3502
    That page is for users. To download firmware you need to be a tech for an authorized branch or dealer. The Technology Solutions Resource Center and the file repository RFG-eSource, http://ssoappprod.ricoh-usa.com:8080/opensso/UI/Login, require an authorized login.
    Since Ricoh does not make firmware available for public download it means that Ricoh considered it intellectual property. Further discussion will be considered a violation of Forum Rules and under Rule 10 could result in your being banned.
    • copier tech
      • 8097
      Originally posted by craigp
      Hey guys,
      [ATTACH=CONFIG]47731[/ATTACH]
      Firmware is not available to the end user.
      Should you should you wish to upgrade the firmware drop us an email, happy to supply it for you.
      Firmware Update - Printer & Copier Firmware
      • GIUBOSS
        • 1382
        Hey guys,
        Why would you like to update the firmware? What problems have you encountered?
        • anothertech
          • 1756
          Why not update firmware, it fixes a long long list of issues, most commonly scanning, but many others as well.
            • 36733
            And if the problem is not one that can be corrected with firmware? That is probably why GIUBOSS asked.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Hey guys,
              Only available to credited ricoh service engineers if your machine is under contract just ask your service provider if not send copier tech a pm they could point you in the right place.
              Always best to keep all firmwares up to date.
              Regards Mark
              • anothertech
                • 1756
                I was just saying it's a good idea to always update the firmware when you obtain a new machine, new or used does not matter, to head off any problems. A lot of people are just living with problems because they figure that's the way the machine works, not knowing that problem has been fixed a long time ago with firmware.
                • copier tech
                  • 8097
                  Exactly.
                  • tsbservice
                    Field tech
                    • 7906
                    Exactly.
                    Mine machines in the field are almost always up to date with newest firmware. That doesn't mean firmware fixes everything but I like to be proactive. That said without knowing what's the real problem it is shot in the dark. First thing comes first - what's the problem?
