Ricoh SP C821dn cyan toner reads empty even with new cylinder
  • rkagerer
    • Jan 2021
    • 7
    I have a Ricoh Aficio SP C821dn (aka product code G189 / SAVIN CLP350D).
    It's been running low on Cyan toner for a few months (we do a low volume of printing). The machine finally complained it was empty and forced me to change it. I took out the old one, broke open a brand new, genuine bottle, shook it vertically for a bit, then installed it. The printer spun and spun but still complained there was no Cyan toner.
    To confirm I was doing things right, I then replaced the Magenta toner (which was also low). That one detected the new toner just fine.
    After a few rounds of letting the machine spin gears trying to get Cyan toner to feed, the ITB Contact Motor stopped working. I received a replacement part today and installed it. Seems to work. But the machine is still complaining there's no Cyan toner.
    Things I tried:
    • Removing and reinstalling the toner bottle
    • Vacuuming around the intake port (in case there was anything clumped)
    • Shake then reinstall the original bottle (it complains "independent-supplier toner has been set" but still senses no cyan)
    • Run SP3-015-005 Forced Toner Supply, and confirmed the Cyan bottle turns.
    • Run SP7-933-012 and confirmed the bottle reads as 100% toner remaining
    • Remove the Toner End Sensor for the Cyan line, clean it and blow it with compressed air, and reinstall
    • Remove the bottle, manually push in the cap and confirm it's not clogged (a cloud and small fountain of toner spewed out easily when I tilted it slightly downward - oops)
    What would be sensible things to check next?
    Note it was working just fine until I replaced the cylinder.
  • Hoosierdaddy
    • Oct 2016
    • 181
    Re: Ricoh SP C821dn cyan toner reads empty even with new cylinder
    Things I tried:
    Try a different cyan pcu. You confirmed it sees a full toner bottle in the sp mode.
      • 36724
      Sounds like a problem with the toner ID chip system. If it uses a contact type connection on the back of the cartridge then it could be a bent contact. If it uses the RFID system it could a corrupted chip or a bad RFID board. Regardless of which it is go into Engine Service Mode and change SP 3045-001 Toner End Detection: Set to 1, disabled. This should allow the printer to operate until the actual problem is identified and corrected. If it still reports no toner then the toner end sensor for cyan is either bad or has come loose from the toner nozzle, you might then need to replace the sensor, the cyan nozzle or both. With toner end detection disabled, you no longer get a warning at 17% remaining to have a ew cartridge ready, when the tner end sensor does not see toner coming out of the nozzle it will give a 50 page warning before going to toner out.
      • rkagerer
        • Jan 2021
        • 7
        Setting SP 3045-001 Toner End Detection worked - it now detects all colors as full and prints successfully.
        Does that rule out a set of potential root causes or verify functioning of any of the components? e.g. Has setting that bit to 1 effectively disabled the Toner End Sensor component (which the tube from the feed nipple leads to)? Or did it actually verify that the sensor is working? If not, can I swap sensors between colors temporarily to diagnose the blue one?
        While I was awaiting answers, I also disassembled, cleaned out, and reassembled the entire toner path from the bottle nipple to the outlet of the pump to make sure nothing was clogged. i.e. The springed nozzle that pushes back on the cap, the end sensor fixture (including the little transparent windows that I'm assuming an LED emitter shines through to a photosensitive detector on the other side?), the feed tube to the pump, and the pump itself.
        Is there any way to test a pump? e.g. When it's running, should it generate enough suction that you can unplug the tube and stick your thumb over the input port and feel if it pulls?
        What should I do to test the chip and RFID board?
        Grateful for your help.
          • 36724
          It ruled out a loose or defective toner end sensor. In fact the end sensors are now the only way to detect the end of the toner in a cartridge. Toner pumps depend more on gravity flow than on suction. If a color starts to fade over a number of pages then the pump system is not working. Ricoh recommends replacing the pump and connecting tube as a set. A lot of pumps have been replaced over the tears only to be back out later because the tube is clogged. In cleaning out the connecting tube you may have actually created a future problem. The inside of the tube is coated with Teflon to prevent clogging. Cleaning can damage the coating which leads to clogs.
          • rkagerer
            • Jan 2021
            • 7
            Thanks. All I used to clean the tube was air suction. There was no clogging or clumps or anything, and I didn't push anything through it. Hopefully that didn't pull off any teflon or introduce contaminants, but I appreciate the warning and will keep it in mind if it becomes problematic later.
            I'm inclined to follow your original instincts that it may be an RFID or chip issue. But I'm a little confused that the printer can read the info off the new bottle in spite of that (SP7-933-***).
            I'll order a new blue bottle and see if that solves it. If it doesn't, any suggestions to troubleshoot the RFID board?
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              ^THIS^
              I'd be replacing the pump and hose....a cheap enough exercise
              As Slim stated...turn off end detect and use the machine as normal...if that particular colour begins to fade away then it's a toner supply issue.
              Very common issue for this particular model.
              Also...just curious...are you a copier tech or an I.T support guy?
              • Gift
                • Mar 2011
                • 2444
                +1 for the pump, was a common cause back then with the entire SPC/MPC series
                • fshead
                  • 2356
                  they dont get that till machine has quenched its need for toner in the dev unit it will not update the toner cartridge as new..
                  So i too say it might be a pump failing
                  • luca72
                    • Oct 2017
                    • 1673
                    Things I tried:
                    toner pump, that machine is similar to mpc2500, 2800, etc ... I remember that they always broke, I changed dozens of them, go easy
                    "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
                    • rkagerer
                      • Jan 2021
                      • 7
                      To follow up on this... the new Cyan bottle arrived. Until now I'd been using the printer with the Toner End Detection set to 1. Before installing the new Cyan bottle, I tried changing Toner End Detection back to 0 and it now detected the existing Cyan bottle (albeit only at about 1/3 full, which is much less than it should have been as the bottle was brand new 3 weeks ago with very little printed since). I used the printer like this for a couple weeks.
                      Today it said Cyan was empty (even though I can feel lots of toner inside). I switched bottles to the brand new one, and it tried loading toner but still said it's empty.
                      I've set Toner End Detection back to 1 again and stuck with the first bottle. I'm going to run until the Cyan starts to fade.
                      I'd really like to get the printer working properly again, though. From comments above it sounds like either it needs a new RFID board or pump. Is there a way I can rule out which one of those it is?
                      Thanks, grateful for any help!
                      • Gift
                        • Mar 2011
                        • 2444
                        Save NV Ram Data via SP on SD Card -> then Memory All Clear -> Reboot -> Restore NV Ram Backup
                        That helped me in most cases with false Empty Bottle Messages (if nothing hardware related is faulty of course). It's easy and fast to give it a shot. I also needed to do this after changing some pumps because the machine wouldn't recover the toner itself for whatever reason.
                        • rkagerer
                          • Jan 2021
                          • 7
                          Thanks Gift, I'll try that.
                          I just realized I haven't tried this, either. Are there toner sensors in the PCU?
                          • Gift
                            • Mar 2011
                            • 2444
                            so what did the trick? the sales guy^^?
                            • rkagerer
                              • Jan 2021
                              • 7
                              Closing the loop on this.
                              The cyan color did fade out over time, and in the end, replacing the pump solved the problem. Thanks everyone for your help!
