[ATTACH=CONFIG]48317[/ATTACH] ricoh mp c3003 - urgent thank you
Ricoh mp c3003 , error sc552-002
Re: Ricoh mp c3003 , error sc552-002
Can you post an English translation of the test on the screen for those of us that don't read Italian. As for the service code what have you tried so far? Have you checked those items in the trouble shooting in the service manual for SC553-002 and SC553-003? Do you even have a service manual? -
Copy/paste this into google translate.
Try executing SP5810-01
- Code: SC552-02
- Description: Fusing Central Thermopile Does Not Reload (T21) degrees C not reached after heater 1 ON for (t3) seconds.
- Causes: • Thermopile lens dirt • Thermopile modification, float • Outside input voltage guarantee • After excessive temperature rise prevention unit operation
- Remedy: • Replace the thermopile • Make sure that the input voltage is within acceptable limits • Replace the fusing unit
not sure but
you might have to do the pico fuse reset in service mode.
ALSO inspect fuser belt and pressure roller,thermisters for buildup...
AS they ask crazy $$$ for those pico fuses I myself made a reset jig
with door microswitch,6 feet of thin wire and connector from old thermister"mp6001".
The timing of when to press and release switch does come into playComment
not sure but
tullio, little information! how many prints does it have? the sleeve / fuser has already been replaced in the past, what have you tried to do?..its destroyed? .. anyway, try cleaning the thermopile lens, thermistors and machine-fuser contacts, and go 5-810, follow the flow chart on manual"loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)Comment
It may have changed but Ricoh used to tape one of the pico fuses inside the box that a new sleeve assembly comes in. I have replaced a lot more sleeve units for reasons other than service codes requiring reset. At the time I retired I had about 6 of them in my small parts box on my work bench. I also carried 2 in my tool kit.Let us eat, drink, and be merry, because tomorrow we may die!
I wonder how many techs have thrown out the box without even checking for the fuse.Comment
