Paper jams with double-sided printing on Ricoh Aficio MF C2051
  • Jens_Berlin
    • Mar 2021
    • 7
    [Jamming] Paper jams with double-sided printing on Ricoh Aficio MF C2051
    Hello!
    I am using the Aficio MF C2051 copy-printer.
    The problem is that the printer has recently started to jam when printing on both sides of the paper. Before the paper jam occurs, the printer makes a loud noise that sounds as if the paper sheet is no longer being transported properly by a roller in the printer and the rubber rollers on the paper are slipping. This is a scraping, creaking humming noise. The paper jam usually occurs in such a way that I have to open the rear flap and then open the inner flap in the machine with the blue lever "B". Behind it there is a sheet of paper that is printed on one side and where the toner is not yet fixed but about 3/4 of the toner has been applied.
    When I remove the jammed paper, printing usually continues, but after about 20-30 sheets the problem occurs again.
    I suspect it has something to do with the feed into the fuser-unit.
    Does anyone have any experience with the machine or the problem? What can I do?
    I'm happy about any hints
  • ridgemill
    • Sep 2017
    • 180
    Re: Paper jams with double-sided printing on Ricoh Aficio MF C2051
    Most duplex jams, for this model, are caused by the duplex entrance guides breaking. If you open the right door, and look at the guides on the top; take note of any broken fins.
    Also, the duplex exit sensor may need cleaning.
    We find that most of the noises these make, are caused by the oil felt, inside the fusing sleeve, going dry.
      • 36689
      The letter jam location "B" is to tell the operator where to look for the jammed paper. It has nothing to do with what caused the jam. Can you tell us what the actual jam code is? It will be in the form o the letter J followed by a three digit number. That number tell us techs which sensor detected the jam and whether it was a lead edge jam or a trail edge jam.
      • Mark Bbb
        • Jun 2012
        • 1662
        As mentioned before the 'claws' of the junction gate duplex enterance were broken and had falen everywhere into the machine and in the paper path.
        I also think that the ITB belt is thorn.
        Fixing this problem by yourself correctly as a user will be very difficult.
        • Jens_Berlin
          • Mar 2021
          • 7
          Is there are log of the errors available on the machine, so that I can find this error-code? When I download the standart-log from web image monitor with admin login I can not find error-codes...
          • copier tech
            • 8095
            Originally posted by Jens_Berlin
            Hello!
            This noise you are referring to is caused by the fuser, the lubrication dries out.
            You can simply replace the fuser sleeve ass'y this will stop the noise & jamming.
            • Jens_Berlin
              • Mar 2021
              • 7
              After printing some pages and trying to reproduce the error for the error-code now the machine stopped and shows an big error message on the screen with the error code "SC553". I can not click the window away, it is blocked. Showing a service-number that I should call...
              • Jens_Berlin
                • Mar 2021
                • 7
                O.k., I managed to solve the problem with this video: Error code SC553 rest RICOH Aficio MP3350/MP2550/MP2591/MP3391 - YouTube
                • Debs1964
                  • Oct 2010
                  • 1687
                  SC553 is a fuser error, along with the jamming, and noise issues you are experiencing, I think you need to call a technician, it sounds like some fuser parts are required on this device. It's not a good idea to reset error codes without having the fuser checked first as some of them indicate an overheat condition, if you reset the code on a device that has overheated then you are heating up parts that are already too hot, this will cause more damage to the device, requiring further parts to need replacing
                  There are 10 types of people in this world, those who understand binary maths and those who don't
                  • Jens_Berlin
                    • Mar 2021
                    • 7
                    Original Ricoh Fusing Unit D106-4006
                    I think for this price it is not worth calling a technician... might be more expensive.
                    What do you think?
                    • Jens_Berlin
                      • Mar 2021
                      • 7
                      Thanks for the hint! Do you mean this part: FUSING SLEEVE ASSEMBLY RICOH AFICIO MP C5502 C4502 MPC5502 MPC4502 D1444032 | eBay
                      • davel
                        • Oct 2011
                        • 1075
                        No, that is not for your machine.
                          • 36689
                          NO! Wrong model completely. What you need is D1064002 Fusing Unit (EU) is you are going to replace the entire unit. D1064002 has been replaced by D1064006. Here is a UK source if you don't want to go directly to Ricoh-EU. Ricoh Aficio Fuser D1064006 MPC2051, MPC2551 Original
                          • luca72
                            • Oct 2017
                            • 1673
                            Hello!
                            you need to look at the jam code in sp, if you have any j019, it is more convenient to replace it complete, get the price quoted by ricoh, we pay it around 140-150 euro....remove the duplex and turn it upside down, and shake it a little, so any broken pieces of plastic from the bill gates will come out
                            "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
                            • Jens_Berlin
                              • Mar 2021
                              • 7
                              Originally posted by luca72
                              jam code in sp,
                              What does this mean? Where can I find it?
