I have a similar issue happening and thought I'd reply to this rather than starting a new thread. My issue is coming from black. The print out is significantly faded (probably 70%) and I will get SC348-11 to flare up shortly into any run. In the service manual, this calls for a toner supply issue and for the sub hopper to be replaced.
I have a extra parts machine here and pulled the sub hopper off it and changed it out. No luck. I tried vacuuming the supply line as well. When I go through the processes for DEMS and any others, they all fail on black. I just put a new toner bottle in just before this happened and wondering if there was a clog in the supply line further up than I reached with the vacuum.
Does anyone have any suggestions on how to test/remedy this? The machine is in the middle of a large book run right now and desperate to get back online.
