Ricoh MP C4504 SC569-00
  • laser801
    • May 2014
    • 148
    Hello Ricoh Peeps... Working on a MP C4504 popping a SC569-00. Fuser or Drive??? What is most likely??? Looking around for spare fuser now...Little help would be much appreciated. Never encountered this yet... Thanks in advance, "Laser801"
  • mikadonovan
    • May 2008
    • 2936
    Re: Ricoh MP C4504 SC569-00
    Did you already check this stuff?
    NEVER ASSUME ANYTHING
    • luca72
      • Oct 2017
      • 1673
      Ciao, to begin with even if the macchine is different,but the concept is identical, I am going to tell you this bulletin, this is what the ricoh goes through...
      instead listen to me, try to check that group (pressure release motor unit), I had the same problem, and I solved it by carefully cleaning the one-way bearings on that component (shown in the photo) with a lot of alcool, a screw driver with over a rag and strong air blow,(the gears with the bearings, you have to pull them down obviously) removing the seigers.
      now it's been working for a year, and I haven't had any more problems...dont put oil or grease!
      the operation are pretty fast,
      a few pieces of plastic, a fan, and a few screws
      let us know...
      "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
      • copier tech
        • 8095
        let us know...
        [ATTACH=CONFIG]50624[/ATTACH]
        +1 on this. I usually spray some WD40 etc into the one-way bearing, you can access this from the RH door.
        • TS3
          • Apr 2020
          • 1
          let us know...
          Thanks for taking the time to post your suggestion. I believe this has fixed my SC569 on the MP C4504 & saved me a bunch of cash.
          The removal procedure of the Fusing Drive is only a little intimidating if you are not used to servicing Ricoh's.
          Just use your head and look for the shortcuts to the screws and it will work just fine.
          Dave
