Ricoh pro c5200
  • gilbert
    • Oct 2017
    • 38
    [Misc] Ricoh pro c5200
    Hi
    Any ricoh tech in this forum .i have this device Proc5200.
    My client is complaining that he is having paper jams
    which is being counted as completed printed job.
    He anyone experienced this and is there any SP mode which needs to be changed
    Please assist
  • copier tech
    • 8093
    Re: Ricoh pro c5200
    Originally posted by gilbert
    Hi
    Please assist
    As I understand only when the print is exited does it count on the meter.
    However how many time does the machine jam for this to be an issue!?
    • gilbert
      • Oct 2017
      • 38
      Re: Ricoh pro c5200
      It does not have jamming issues ,the meter will click even when there is
      a normal paper jam or jam is created.
        • 36685
        Re: Ricoh pro c5200
        The first thing you need to find out is what the numeric jam code is being displayed when the machine stops. If it is J001, then no true jam has occurred and no entry will be made in the jam history. J001 is a jam at power on. When it occurs during operation, it usual is a bad interlock switch, the machine thinks someone opened and then closed a door. When it occurs during a print job from a computer, the computer will restart the job from the beginning.
        • davel
          • Oct 2011
          • 1074
          Re: Ricoh pro c5200
          If it is not jamming often what is the problem.
          • dalewb74
            • Feb 2018
            • 1107
            Re: Ricoh pro c5200
            as stated above what is the jam code? where is the jam located? does the paper tear? does it accordion? need more input.... we're not mind readers. there is no universal jam...
            • gilbert
              • Oct 2017
              • 38
              Re: Ricoh pro c5200
              latest five jam codes
              J008
              J007
              J099
              Jo24
              J057
              • gilbert
                • Oct 2017
                • 38
                Re: Ricoh pro c5200
                It will print a big job but when it jams the meter will count.
                The many issue is, a customer is question why the device is recording a jammed/damaged prints/copies.
                Latest jam code; J008,J007,J099,J024 and J057.
                  • 36685
                  Re: Ricoh pro c5200
                  What is the total count for jam J001?
                  • mikadonovan
                    • May 2008
                    • 2936
                    Re: Ricoh pro c5200
                    I suppose an easy way to track that is to reset jam counters at every call (or keep a running total from the SMC logging data), and then credit the customer with the amount of misfeeds they had. We used to credit misfeeds/bad CQ images by counting them in a box next to the machine.
                    NEVER ASSUME ANYTHING
