Strange problem IM C300 + Wifi = SC899
  • dave w
    • Jun 2015
    • 230
    Strange issue last week
    IM C300 = Ethernet
    Windows laptops = Wifi
    They have two Wifi connections = Guest & Admin
    Users were on the Admin Wifi and I was on the Guest Wifi
    Both have the same IP = Gateway & DNS, can ping all
    The strange problem was Word / Text docs all print fine, PDF failed on a SC899
    SC899-00 D Software Performance Error (signal reception end)
    Unknown software error occurred.
    Occurs when an internal program behaves abnormally.
    In the case of a hardware defect
    1. Replace the hardware.
    In the case of a software error
    1. Turn the main power OFF/ON.
    2. Try updating the firmware.
    Firmware was updated (package) did both App first, still same issue then by Sd card just to cover all options
    Users were using Google pdf reader which I got them to user Adobe Reader DC.
    I isolated the printer and the laptops with a 5 port hub I had and made a little network, All ok no issues
    After all the head scratching I got them on the Guest Wifi and all was good.
    question = What do you think was causing the issue on the admin Wifi? - I could not do anything IT as it was looked after via a remote company
  • TonerMunkeh
    Professional Moron
    • 3869
    Re: Strange problem IM C300 + Wifi = SC899
    Were they printing the PDF's from Edge? Had that cause all kinds of stupidity.
    Hit it.
    • dave w
      • Jun 2015
      • 230
      Hi TonerMunkeh
      Yes I think they were - limited users in the office last Thursday, I made them download pdf reader DC. all fine on Friday.
      Just after posting this thread the same customer is having the same issue again, and im sure its a user that was not in last week and is using the admin WiFi which I think may be doing something strange.
      Love it when the info I left last week with the user has not been shared with the rest of the office.
      Its a shared workspace with hot desks.
      Dave
      • JayPaul
        • Oct 2012
        • 305
        I doubt it will be to do with guest or admin wifi, it's usually based on the print job itself, the driver/port or firmware. You can probably rule out firmware if you already updated it, worth checking they are using a real driver (PCL 5 or 6 for example) and it is NOT on a WSD port. Then make sure they are actually printing the job properly using pdf reader as you suggested, not just reverting back to edge or chrome or something. There may have been people not at the office when you were last there who are now there, printing using a wrong driver or application. I had SC 899 as my last call on friday and it was firmware on a nearly brand new machine, it had released a new package 2 days after I installed it which fixed it. Then my third call today was another SC 899 and I already knew what it was so sorted it over the phone. They got new windows 11 laptops, which keep setting the printer up on their own, on WSD port and crap class drivers.
        • davel
          • Oct 2011
          • 1075
          Turn off WSD on all new installations, stops windows trying to use it.
          • JayPaul
            • Oct 2012
            • 305
            Been trying for years, usually log into WIM and turn of all ipv4 and 6 WSD options and also started turning off bonjour as well. Windows still seems to see it, plus the 'basic/local' IT guy will think he is adding a new printer correctly on a laptop simply by going 'add new printer' ...searching... 'Ricoh mpc307 ae028758h043' they add it and it automatically puts it on wsd port.
            I have been sarching how to completly stop WSD for literally over 2 years and nobody has found a full on kill switch yet
            • dave w
              • Jun 2015
              • 230
              Originally posted by JayPaul
              released a new package 2 days after I installed it which fixed it. .
              Im going back tomorrow as i cannot remote onto the MFP - Package 2 ? would this be the file =
              IM C400F/IM C300F/IM C300/IM C400SRF Package_02 Ver.5.29
              reason why I ask is because I only updated with, seems same Ver number
              IM C400F/IM C300F/IM C300/IM C400SRF Package(ALL) Ver.5.29
                • 36689
                And if they still get an SC899 when printing from a PDF reader or from Adobe Acrobat, then try going to "Print Preview" and print from there. That will flatten the page which means remove all the unprintable crap like strange graphic characters and scrolling text and other crap like embedded OCR that Ricoh's and other Scan To OCR add.
                • sandmanmac
                  • 3967
                  I do the same, and it's mostly true that disabling WSD will prevent Windows from Automatically setting up network devices as indicated in the Network and sharing center, but what it won't do, is keep Windows from discovering the device through the Add printer wizard, and adding it as an IPP printer on the WSD port which will have the same infuriating results.
                  This is the most common issue I see when my customers have their own IT do the setup. They almost NEVER seem to use the full driver package on a TCP/IP port.
                  While you can also disable IPP, that will result in the Ricoh Connector App becoming unusable, and also have an affect on how Apple devices connect, in my experience
                  • dave w
                    • Jun 2015
                    • 230
                    after the Firmware update
                    System/Copy 5.29 D0C95450R
                    Network Support 18.85 D0C95463M
                    Web Support 4.00 D0C95459M
                    Fax 05.29.00 D0C95454L
                    Scanner 05.00 D0C95457K
                    Web Uapl 4.00 D0C95460L
                    NetworkDocBox 5.29 D0C95461H
                    animation 3.01 D0C95462K
                    Printer 5.29 D0C95474P
                    RPCS 3.23.20 D0C95475C
                    Font EXP 1.00 D2415581
                    PCL 1.08 D0C95476H
                    IRIPS PS3 1.00 D0C95477A
                    IRIPS PDF 1.14 D0C95478J
                    IRIPS Font 1.15 D0AF5577A
                    GraphicData 2.01 D0C95472F
                    HelpData 0.02 D0C95473A
                    MovieData 1.00 D0C95493B
                    MovieData2 1.00 D0C95494B
                    MovieData3 1.00 D0C95495B
                    Data Erase Onb 1.05 D2625244
                    PowerSaving Sys F.L3.25 D0C95453A
                    RicohACT 1.20 --------
                    Engine 2.11:04 D0C95776A
                    I have just checked this by opening the PKG file in notepad - all up to date
                    question
                    in the good old days you can go down the firmware list and see it the mfp firmware was up to date - now you just see an Package and no breakdown - am i missing something?
                    Dave w
                    • dave w
                      • Jun 2015
                      • 230
                      New symptom occuring now
                      Restart screen
                      Functional Problem Detected
                      Press [Restart] after the current process
                      just stays on that screen
                      after a rebbot all ok until somebody prints
                      no sc errors only software error 899
                      I have noticed the bootup time and all apps on screen can take longer than normal when on the network. seems to be quicker disconected from network
                      prints pdfs ok using a usb stick
                      would it be a hdu?
                      • dave w
                        • Jun 2015
                        • 230
                        Quick update
                        Info back from Ricoh with the info I Gave and hope this helps somebody in the future
                        I will check the toners as guided before I remove the HDU and do another firmware update.
                        often with SC899 the issue can be a print job, have you rebooted the device without the network cable attached to see if the error occurs please?
                        If the error doesn't appear please ask the users to delete any jobs in their print queues and then reboot the device, also check the drivers they're using, if trying to print a web page for example this will cause the error.
                        If it happens without a network connection please remove the toner bottles then reboot, if the error doesn't occur and all you see is load toner then it may be an error with a particular bottle so please load the toner until the error appears and then check/clean that bottles chip or replace.
                        Also worth checking are the toner ID chips aren't dirty or twisted as may be not quite connecting.
                        It's also worth disconnecting the HDD and then updating the firmware again before refitting in case of a corruption issue.
                        • dave w
                          • Jun 2015
                          • 230
                          UPDATE FROM CUSTOMER
                          I have checked all of the toners and the chip at the end was totally clean on all of them.
                          There has been no error with the printer being off the network this afternoon, I have printed numerous docs no problem from a USB stick.
                          The plot thickens!
                          • anothertech
                            • 1755
                            Have you checked SP7403 and SP 7404 for details of the SC899?
                            • dave w
                              • Jun 2015
                              • 230
                              No
                              What would it tell me?
