My Ricoh MP C2051 is installed and printing and Scanning to Folder but within a particular Application online or on System its not detecting as a scanner any advise ?
Ricoh MP C2051 NOT DETECTED FOR SCANNER
Re: Ricoh MP C2051 NOT DETECTED FOR SCANNER
Ricoh's TWAIN drivers only work with 32-bit applications. If the application you're trying to connect with is 64-bit, it will not work with those drivers. One possible workaround is to make sure that the Scanner feature is advertised by WSD. In most cases, we turn off WSD entirely, but we have had instances where a scan application can use it to find a scanner for use. Just be sure to only turn it on for the Scanner function only and not the printer function.
What application is having issues seeing the scanner? TWAIN scanners are more of a curiosity at this point than something we generally see, but it is interesting that scanning with TWAIN or WSD offers features that aren't available when scanning with the device natively.Comment
Network WIA (Windows Image Acquisition) is also available and does work with 64 bit Windows. You may need to use Ricoh-usa.com to download as I checked Ricoh-UK and scanner drivers are not shown as it is considered a "legacy model"
Support and DownloadsComment
Scanner Screenshot.jpgComment
Thank You everyone ... its all sorted on all machines.. much appreciate your help .. after the drivers installation it was the FIREWALL !! disabled it and its working on windows 10 as well
Once again thank you every oneComment
I can see disabling the firewall as a troubleshooting tool, but it's not a long-term fix.
Sent from my BlackBerry using TapatalkComment
Disabling the firewall isn't really a fix, especially if this is a customer machine. There are pre-set rules to open the ports needed for scanning. You'll need to allow those rules to get things working properly.
I will sort out as you mentioned
Its my own personal business and i can manage working with disabling the firewall at the moment and will definitely work on as you mentioned.Comment
