[ATTACH=CONFIG]53234[/ATTACH]
as soon as it is turned on, this error is thrown.
Has anyone happened?
Most likely you have corrupted data on the HDD, or it is damaged.
I recommend that you turn on the device with the HDD disconnected from both its data power and power supply. And try turning on the device.
If the boot is "normal", we can rule out control board problems.
"ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
SC 672-00 is a communication error between operation panel and the controller after machine is powered on. Biggest cause over the years has been the USB cable between the controller and the operation panel, frequent just a loose connection at one end or the other. Could also be a defective controller PCB.
as a first indication I would look at the lighting condition of the row of LEDs on the controller board, for example: if they are all on, or all off it is bad! ... almost certainly the controller is gone
"loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
