Mpc3003 sc370-02
  • kanagavel
    Service Engineer
    • Feb 2020
    • 78
    [Error Code] Mpc3003 sc370-02
    Hi friends, my customer place mpc3003 machine have sc370-02 problem i changed( ID sensor, ITB unit, toner cartridge for all colours, toner dispenser unit all colours) already. I try forced toner done still same error, can't perform sp2111 forced line position adjustment and sp 3110, i try engine memory clear then error solved but i print or copie 1or 2 pages showing self checking then again error code coming, so please if anybody knows how to solve this problem permanently please help me on this. Thank you.
    • 36689
    Re: Mpc3003 sc370-02
    When you "changed the ID sensor assembly, was it a new one or one from another machine? A new one comes with a sticker with 6 values that need to be entered in SP for all three of the sensors. If even one of those values are entered incorrectly, you will have problems. If you took a sensor assembly from another machine, you need to write down the values from the other machine and enter on the machine you are working on. In fact, anytime you remove a TD sensor from a machine you should write down the values and keep them with the sensor. You might also want to check the sensor shutter. It is on the bracket that the sensor mounts to and is supposed to help dust and toner off the sensor.
    • copier tech
      • 8095
      You have an issue with the cyan PCDU what is the PM life & the transfer belt?
      Also there were a few issues with this code on early system/copy firmware so I would start by updating to the latest package first.
      • Code: SC370-02
      • Description:TM (ID) sensor calibration error (C) Regular reflection optical output voltage of the Front or Center or Rear TM (ID) sensor: Vsg_reg cannot be adjusted to within target range. Upper limit (SP3-320-013: initial value 4.5V) Lower limit (SP3-320-014: initial value 3.5V)
      • Causes:Remedy:
      • UNICORNico
        • May 2018
        • 308
        My first question is.
        Why erase the memory of the Engine?
        My second question.
        What did you hope to solve by doing that?
        Strong recommendation, do not have as a first option to erase the memory of the device, if you are not clear, what you want the result to be.
        "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
        • kanagavel
          Service Engineer
          • Feb 2020
          • 78
          Hi sir thank you for your response, sir i took ID sensor from another working machine.
          Sir i dont know about the 6 digit number, can you please explain about that and where should I enter that number in sp mode. Please help me sir.
          • kanagavel
            Service Engineer
            • Feb 2020
            • 78
            • Code: SC370-02
            • Causes:Remedy:
            Hi sir thank you for your response, sir actually I didn't notice the PM value of cyan pcu and ITB but i already reset the PM counter for ITB.
            • kanagavel
              Service Engineer
              • Feb 2020
              • 78
              My second question.
              Hi sir thank you for your response, sir i tried already changed ID sensor and ITB unit all that is why my friend told try to clear the engine memory, so i did it but problem not solved. So please help me on this sir. Thank you.
              • Daniel_B81
                • Jan 2019
                • 38
                My co-worker ran into a similar problem, it started that the magenta dev clogged up and destroyed the magenta hopper as well so he had to disassemble it quite heavily, after everything was switched we ran into sc370 after awhile and followed the troubleshooting guide for it only that we should've followed it stepwise backwards as the problem was a connector to the BCU that wasn't connected.
                • kanagavel
                  Service Engineer
                  • Feb 2020
                  • 78
                  Hi sir thank you for your response, tomorrow I will try this sir.
                  • UNICORNico
                    • May 2018
                    • 308
                    I'm going to seem like an unfriendly to you, but please DON'T DO WHAT A "FRIEND" TELLS YOU.
                    Both you and your "friend" are not proving to have much technical knowledge or experience in this sector, and I recommend consulting with a qualified technician. And I apologize to the colleagues in this forum, if I am being aggressive with my words.
                    I do not doubt that the technicians of this forum (myself included), can help, but, more than giving a slight advice or basic indications, what you need is a qualified technician to be able to do this repair.
                    • kanagavel
                      Service Engineer
                      • Feb 2020
                      • 78
                      Ok sir thank you for your response.
                        • 36689
                        • Code: SC370-02
                        • Causes:Remedy:
                        The (C) in the error description does not refer to Cyan. It refers to the Center of the three sensors on the ID sensor assembly. Those are (F) Front, (C) Center and (R) Rear.
                          • 36689
                          It is fully explained in the service manual.
                          • emiliorsg
                            • Jul 2018
                            • 141
                            I had the same problem and it was caused by the transfer belt, although it seemed to be in good shape, after having fought with the id sensors.
