Ricoh mp c2003 . Error
  • tullio
    • Feb 2012
    • 268
    [attach=config]53362[/attach
  • tullio
    • Feb 2012
    • 268
    Re: Ricoh mp c2003 . Error
    door open. but they are all closed. the sheets are not there. Thanks for your help.
    • luca72
      • Oct 2017
      • 1673
      Door sensor, rdf control board, or both.. its happened
      Look adf input check.sp's for Door sensor status
      One time its happen on different model (mp4002) the same problem its a main Power supply, i have Lost a morning to find a problem
      "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
      • Brianneoe
        • May 2015
        • 318
        Go into the SP mode and check the last error code. You may have a hidden fuser code.
        • tullio
          • Feb 2012
          • 268
          Resolved . short by pass. Thanks for your help.
          • luca72
            • Oct 2017
            • 1673
            Im not understand, can you Say more?
            • tullio
              • Feb 2012
              • 268
              the problem was the bypass.
