mp c407 lines in color prints
  • digicor
    • Jul 2008
    • 1141
    i have a c407 has magenta lines like a charge roller or debris on the lens,, i cant quite find where the lens or where to clean the lenses ... behind the waste box?? i removed it..,,, do you have to remove the PCU to clean the lenses?
    any help with this thanks
    • 36688
    Re: mp c407 lines in color prints
    Do the lines occur in copying, printing or both? If only when copying from the Doc feed, you might have a mark from a gel of fluid ink pen on the slit glass.
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      Surely debris on the laser would be creating a void?
      • davel
        • Oct 2011
        • 1075
        • copier tech
          • 8095
          If you have white lines you could try cleaning the laser units. Remove the copy tray (1 screw) & they are sitting above the PCDU.
          If after cleaning the lasers you still have the white lines replace the PCDU of that colour.
          Or you can strip the PCDU remove & clean the dev unit.
          • davel
            • Oct 2011
            • 1075
            Are the lines magenta down whole page, try another PCDU.
            • digicor
              • Jul 2008
              • 1141
              Just print
              • digicor
                • Jul 2008
                • 1141
                No just in the image not magenta lines, but void in the prints that seem to be magenta..
                • L0rdC
                  • Feb 2021
                  • 82
                  if there is no color... dirty laser or developer failure, lack of developer if it changes area or something obstructing the blade
                  • digicor
                    • Jul 2008
                    • 1141
                    color units only have 16k on them, thank you for your post
                    • L0rdC
                      • Feb 2021
                      • 82
                      can post a test print?
                      • digicor
                        • Jul 2008
                        • 1141
                        • L0rdC
                          • Feb 2021
                          • 82
                          [ATTACH=CONFIG]53582[/ATTACH]
                          is a cyan failure, check developer roller
                          • digicor
                            • Jul 2008
                            • 1141
                            DV roller is solid,, im cleaning the charge roller..
                            • digicor
                              • Jul 2008
                              • 1141
                              okay i had this old trick of running a piece of paper behind the dv roller and movint it from side to side from the old days when debris would somehow make its way between the doctor blade and the dv roller
                              so i did that to the cyan,,, and cleaned the charge roller *very lightly with a very clean cloth and some windex or alcohol,, justa drop make sure it dry before you spin it to the next section**
                              this seems to have cleared it up,,, thank for all the responses
