I have a 4054, which prints all the documents, but only in one copy, if you put quantity 3, only one sheet comes out. self
below the characteristics of the installation, and the tests I did
installation: driver distributed by windows server2019 in active directory on 10 pc
mp4054 full fw update
test:
reinstalled in local = run for 3 tests, then same
try unidriver & v4 (server and local)= NG
try mp3353 driver for test = NG same problem
create new ip port = NG
clear sp printer application = NG
try with my linux laptop with cross cable=OK
change with another mp4054 not fw update = NG
in the end i found that if i change the 1st tray (select auto to tray 1) everything works! but the trick doesn't work with tray 2,3,4.
do you have any ideas?
ricoh say me that try to change in user tool (fold rotate continueauto) but that doesn't work either
test:
