Ricoh not accessing USB drive
  • niceville318
    • Feb 2014
    • 43
    [Misc] Ricoh not accessing USB drive
    I have an Ricoh MP 9003 and the customer is using a marketing 120MB USB device with their logo on it to scan files to. The Ricoh recognizes it is plugged in to the slot but can not access the drive. I have reformatted it multiple different ways but no change. I've used other drives in that slot, all different formats and sizes from 14MB to 128GB and they have all worked, so I know the slot works.
    I plugged the marketing drive into a Sharp MFP with no problems, I was able to scan and print from it. I then plugged it into an Ricoh MP C4053 and it would not work just like the MP 9003.
    I looked at the properties and changed permissions but I can't think of anything else to do. Why does every other USB drive work in this slot but this one? They've used them in the past with no problems. This is a new batch of drives they just reordered and now can't use on their Ricoh MFPs. Any suggestions would be helpful.
  • dalewb74
    • Feb 2018
    • 1104
    Re: Ricoh not accessing USB drive
    purchase from a different manufacture. some just won't work. since you said you reformatted i am guessing you tried fat32? all files on the drive are only jpg or pdf and nothing else?
    • niceville318
      • Feb 2014
      • 43
      I don't think the drives were purchased from a different source. I tried FAT32 and it doesn't matter what is on the drive, it won't access it but does recognize it's plugged in.
      • Gift
        • Mar 2011
        • 2443
        It's probably just not compatible, this happens. Years ago my boss ordererd a bunch of sticks with our logo on it and these refused to work with Ricoh, too
        I think it depends on the sticks internal memory controller, some are not compatible with the chipsets on the panel PCB.
        • mikadonovan
          • May 2008
          • 2936
          Yes. I just perused Ricoh documentation, and they state that they must be formatted to FAT 16 or FAT 32, AND that all drives will not be compatible. I have run into 1 or 2 over the years that simply would not work.
          NEVER ASSUME ANYTHING
            • 36674
            Try a drive from a different manufacturer.
            • sandmanmac
              • 3967
              Seems you answered your question multiple times before you even posted it here.
              Basically, the answer is... Sometimes $hit happens.
              • niceville318
                • Feb 2014
                • 43
                I tried two USB's i carry and they both work, one is formatted FAT and the other is FAT32. The customer's drive does work in another manufacturer's MFP down the hall, it just doesn't work in any Ricoh I've tried.
                • tonerhead
                  • Sep 2009
                  • 582
                  Direct from MPC3502 users guide.
                  • USB flash memory devices and SD cards are supported for direct printing. However, certain types of USB flash memory devices and SD cards cannot be used. For details, contact your sales or service representative.
                    I know it's stupid, I have run into this before also and it makes no sense. One case did make some sense though and it was a flash drive that came from a linux box that was formatted fat32. Reformatting in windows or Linux did not change anything. I completed a low level format on it and then reformatted to fat32 in windows and it worked.
                    On an interesting side note, I have a 2gb sd card that won't do ricoh firmware, but works everywhere else. I also have a 16gb sd formatted fat32 that works fine all of the time. That's Ricoh for you.
                  I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
                  Especially when it comes to sex
                  • tsbservice
                    Field tech
                    • 7897
                    Those Japs are just picky ask any Konica Minolta tech if any USB stick would get firmware most will answer - not exactly
                      • 36674
                      Most of these "marketing' drives with company logos on them on usually extremely inexpensive (El Cheapo) devices. They work with Windows read/write algorithms for awhile but most MFP do not use multiple algorithms. THey make one attempt to read the folder structure and if that fails, they error. THe 2 you have are most likely either Sandisk, PNY, Samsung, Panasonic or another quality brand.
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3945
                        • tonerhead
                          • Sep 2009
                          • 582
                          Back around 6 years ago when 64 gig flashdrives were probably around $100, I bought 3 from Wish.com for $10 each. Junk. I was able to get about 3 writes on each before they failed. A friend of mine gave me 3 promotional 4gigers because I hooked up his wireless printer. One failed almost immediately, the other 2 still working though.
                          In all my cases though the media didn't work in anything. His at least work in some things. I hear what is being said though. Most likely the promotional drives are el-cheapo-delux. It might be worth running a scan on them to see how bad they really might be so you have something to show the customer to vindicate yourself.
                          • Gift
                            • Mar 2011
                            • 2443
                            El Cheapo
                            I think it's also funny how poor the write speeds of these "cheapos" usually are, not shure why somebody buys a 256gb stick with 2mb/s write performance.
                            • luca72
                              • Oct 2017
                              • 1672
                              try to format the sd/usb key with panasonic "SD card formatter"(its free, seek on google), if not the law so, then it is incompatible, there is nothing to do
                              "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
